Winch dump trailer build
/ Winch dump trailer build
Lots of great info and suggestions here guys, thank you. I wish I had started with 2x4 wood for the arms when I was trying to figure out lengths.
Here is we're I'm at with this as of today. You have to remember I wanted something lite that t I could pull around my yard with my atv as well as being hyway ready, also really hopped it could haul 1 yard of rock or gravel. (Tall order for a 3000lb trailer).
Anyways, here is we're I'm at. I went all out with the first test, it's about .8 of a yard of mixed gravel. Honestly I was pretty nervous something was going to let go but t held up fine!
big tex 5x8 into Homemade light weight winch dump tip trailer - YouTube
/ Winch dump trailer build #22
Nice, looks like you have that folding arm geometry figured out, that dump should come in handy a lot.
/ Winch dump trailer build #23
My self made dump trailer measures 5 x 9 and has stake pockets.
The "Hinge" is the trailer axle wheel bearings.
I modified a camper jack to raise the bed for tilt.
Works well but I cannot go vertical for two reasons...
1. The rear overhang will hit the ground at about 50 degrees
2. The camper jack has limited lift range.
/ Winch dump trailer build #24
:thumbsup:Congratulations! I like how you stuck with it until you figured it out.
/ Winch dump trailer build #25
As long as you can dump out gravel/dirt, I'd still call it a success. When you get a change grab a pic of that folding lift arm, I might want to make something like your trailer sometime.
/ Winch dump trailer build #26
It up at my brother's ranch... will try to get something to post.
2014 INTERNATIONAL DURASTAR 4300 EXT CAB DUMP TRK (A64280)
2014 INTERNATIONAL...
20ft 2-Door Shipping Container (A61572)
20ft 2-Door...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2005 John Deere LX5 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
