Winch added to the oliver oc3
   / Winch added to the oliver oc3 #1
plastikosmd
Made/mounted a bracket on the oliver I considered selling and installed a winch (firewood extraction)
   / Winch added to the oliver oc3 #2
Looks good.
   / Winch added to the oliver oc3 #3
Very nice, have any more pics of the OC3? I have one with an Anderson blade that is waiting restoration.
Has rear pto (belt and 6 spline), also gear starter conversion, distributor conversion, Auxiliary transmission conversion, list goes on
   / Winch added to the oliver oc3 #5
I like it! I've been keeping an eye out for a model A trans. to add an aux. to mine.
Curious about the distributor conversion, does yours the IXB engine?
What do you mean by gear starter conversion?
Here's mine in all its rusty glory.
Ixb yes
Love the patina on that machine!
Mated a farmall distributor in place of old magneto and also got rid of the points, using one of the new optical systems
Gear starter is not really a “conversion” I guess, just changed out old for a new geared starter (reduction for easy starting)
The auxiliary transmission is handy for drive and pto control. Also gas and hydraulic tanks are moved outboard on loader frame, battery moved in closer to engine making more room
   / Winch added to the oliver oc3 #7
Thanks, plan on doing a full restoration one day, mechanical for now, I did drive it up and down the driveway once but it needs a lot of work.
With the blade it really needs the aux. trans.
This one has a fairly new Mag on the it so I'm probably going to leave it.
Biggest thing I know i need right now is a radiator, might see if the radiator repair places around me can re-core it.
   / Winch added to the oliver oc3 #8
Will keep my eyes open for an extra
I have a parts machine but holding one for me
   / Winch added to the oliver oc3 #10
Don't blame you, radiators are hard to find it seems. Mine has a leak but also is missing about 1/4 of the core and was soldered up at some point in its life, the tanks seem to still be ok.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVELER (A54757)
UNUSED WOLVERINE...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
John Deere 85G Quick Attach Brackets (A50775)
John Deere 85G...
2022 Toro Workman 07921 Electric Utility Cart (A55851)
2022 Toro Workman...
