Backhoe Will this work with the BX24 backhoe ?
/ Will this work with the BX24 backhoe ? #1
TINYTRACTORSERVICE
Will this work with the BX24 backhoe I am looking to take the backhoe and make a Mount on the back of a Suzuki Samari Quick on and off just like the BX then take this Hydraulic powered unit from this post hole unit and Mount it in the back of the Samari to power the backhoe put a seat in the back . This is so I can go down the road or any where that little 4X4 can go and do some backhoe jobs . So what do you think ??? will it work ?? think the Hydraulic unit will do the job?? Give me some input Pls. THANKs TC TINY TRACTOR SERVICE . this is the power pack unit Id like to use ;) Harbor Freight Tools - Quality Tools at the Lowest Prices
/ Will this work with the BX24 backhoe ? #2
In my area there is an old Ford Bronco, about a 1971 model, that has a permanently attached post hole digger in the back.
I've also seen an old jeep cj running around with a little backhoe...
The Samurai is smaller and lighter...
/ Will this work with the BX24 backhoe ? #3
I don't see why it won't work as long as isn稚 mounted so that you can still use the stabilizers. There are companies that build small dump trailers with a backhoe on the back. These are used to clean the pits out at car washes. That is something else you might look into. You would need to have a cemetery bucket and take the teeth off. Cemetery buckets have the pin holes in a different location so that square corners can be made.
/ Will this work with the BX24 backhoe ? #4
A b/h on the back of a Sammi would be an interesting project.
Note that the Suzuki is very light, and that is somewhat of a
limiting factor. I weighed my current 88, after removing the
body and it is only 1200#. Keeping part of the body will push
that up a few hundred #.
The frame is rectangular tubing and that is good, but the height
off the ground in the back is an issue. You will need longer
outrigger feet or mount the hoe below the frame. The BT601
prob weights 700 lb or so, with the subframe.
Also, for hyd power, you can buy a decent pump for $100 and a
10hp motor, and direct-drive the pump for the flow you need.
That is how it is done with the CADDigger home-built units.
If you do it, post some pix. I have seen PHDs on jeeps, but not
backhoes.
I am not Joking I like some input on this I think this would work grate.To go any where w/a backhoe / freeway/backroads intown where ever that little 4x4 can go??? :cool: THANKs TC
/ Will this work with the BX24 backhoe ? #8
Know why you don't see any of the Jeep CJs from the 40s & 50s with the backhoe and/or trencher attachments still in use anywhere or see them anywhere other than museums or collections?
'Cause all the frames broke from the stresses that they subjected too but not designed for.
And I hate to think what the rear suspension will bo with all that weight hung off the back, BTW how will you keep the front wheels on the ground?
Don't get me wrong, Samis are tough little buggers, and I've personally seen them go some amazing places and do some amazing things, but I think you just might kill it with that idea.
/ Will this work with the BX24 backhoe ? #9
I think the sammy frame could be a problem without some plating and having the front wheels on the ground isn't as stable as sitting on the bucket but go for it. The bx is about the same weight as a sammy and that is a little hoe. But really how much trouble is loading and unloading the bx? How often are ya gonna do it? And every time I dig something up I need the fel/box blade to fix the hole and/or dirt back up. Maybe not having the bx along isn't such a good idea afterall.:cool:
/ Will this work with the BX24 backhoe ? #10
Hey, TC, I think it is doable, but you will just need to modify
some things you may not be planning. As Todd states, the
frame will need reinforcement and suspension will need
stiffening. You will want to mount everything as forward
as possible to minimize lightening the front end too much
for driving on the road. Since that makes everything higher,
your outriggers won't be long enough. If you just hang the
hoe off the back of the frame, you will have 75% of the
weight on the rear tires and control on the road will be dicey.
It is true that at the job site if you have no way to move
dirt around, as with a loader, you are very limited. Before I
bought my first tractor, all I had was my CADDigger, and that
was very limiting. BTW, the CADDigger can be towed to jobsites
on the highway and does not compromise your vehicle. JerryG
mentions attaching a hoe to a trailer. If you did this with your
BT601, you would have a good compromise solution. It would
be towable and make use of your hoe, relatively unmodified.
/ Will this work with the BX24 backhoe ? #11
My water utility company has several F600 chassis cabs with substantial frame mounted backhoes.
The trucks also have high output "screw" air compressors and jack hammers.
Last month, my neighbor saw water bubbling up from the street about a block from his home. I called it in and within 30 minutes the "Rapid Response" Backhoe was on the job.
I'll take a picture the next time I see the 71 Bronco with the rear mounted post hole digger. The name on the side of the vehicle is ACE Drilling.
/ Will this work with the BX24 backhoe ? #12
Bet you a dollar the BX subframe is a thicker piece of steel than you can find anywhere on a Suzuki truck...
/ Will this work with the BX24 backhoe ? #13
no question about it...the grill guard alone is a killer little piece of metal.
/ Will this work with the BX24 backhoe ? #14
I'm betting that Suckuki couldn't haul half the weight of that BH, let alone trying to power it with half the horse power it had with the tractor.
I no the frame WILL need beeeeefing up. The(Suckuki) sammy CAN haul the backhoe any where you would need to go;) .I planned on taking the back off of the sammy up to the back tire and working in the backhoe there. NOW far as the power Hydraulic unit ??? you think the 9hp motor will work ???
/ Will this work with the BX24 backhoe ? #16
It will supply the hoe with 9 hydraulic horse power.
What it can accomplish with that would be just guesses at most.
What does the BX24 put out ?
/ Will this work with the BX24 backhoe ? #17
TINYTRACTORSERVICE said:
you think the 9hp motor will work?
Would depend entirely on what pump you put on it. For force comparable to the BX, it would operate around 1/3 the speed. That is pretty slow...
/ Will this work with the BX24 backhoe ? #18
The bx only has a 5.5gpm pump and 23hp. The hoe never has worked the engine much (the relief blows before the engine slows) in my hard pan. 9hp is just alittle less hp than ya need for 6gpm @ 2500psi according to what I know, so it should be good enough (10hp would give ya some headroom). But a 10hp engine and 6gpm pump (plus the miss junk) the ain't cheap. I'd look at a pto for the sammy but I don't know anything about sammy transmissions.:cool:
/ Will this work with the BX24 backhoe ? #19
You could always mount a snowplow pump onto the engine and use that to power the hoe. **** those little Samari's didn't have much more than 9hp engines did they, lol.
The real question is would it be worth the work vs. just getting a trailer to haul the BX around. A BX24 would go any place a Sammy would (other than down the road).
The thing here is;) is to be able to get in it get there do the job then poof your gone. like going to the back woods cabin or going up town to the doc's place to dig that hole his wife needs?lol and now that gas and diesel here is 3.00 and 3.46 gal Diesel :mad:. My box van works good but its diesel and get's maybe 7 to 10 mpg :( the sammy would get 20+mpg. I was looking at this to power it Harbor Freight Tools - Quality Tools at the Lowest Prices or may be a LOG SPLITTER set up like Harbor Freight Tools - Quality Tools at the Lowest Prices just for the tank,motor,pump set up..
