Will this spool work
/ Will this spool work #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am designing a 3pt hitch for my tractor. I was given 2 double acting clinders and still am not sure this is the direction I want to go.... That said,,,
lets say each cylinder is going to act as an arm lift. This would allow me some tilt control I beleive. But I want both cylinders to float Would this spool valve float both cylinders? I know little about this clearly...
Surplus Center - 2 SPOOL 8 GPM PRINCE MB21GB5C1 DA VALVE W/FLOAT
/ Will this spool work #2
Sounds like only one has float:
"Spool Details:
Spool 1 DA cylinder spool, spring to center with detent float
Spool 2 DA cylinder spool, spring to center"
/ Will this spool work #3
Maybe you could use one cylinder for lift and one for tilt.
Bruce
/ Will this spool work #4
