Will this spool work
/ Will this spool work #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am designing a 3pt hitch for my tractor. I was given 2 double acting clinders and still am not sure this is the direction I want to go.... That said,,,
lets say each cylinder is going to act as an arm lift. This would allow me some tilt control I beleive. But I want both cylinders to float Would this spool valve float both cylinders? I know little about this clearly...
Surplus Center - 2 SPOOL 8 GPM PRINCE MB21GB5C1 DA VALVE W/FLOAT
/ Will this spool work #2
Sounds like only one has float:
"Spool Details:
Spool 1 DA cylinder spool, spring to center with detent float
Spool 2 DA cylinder spool, spring to center"
/ Will this spool work #3
Maybe you could use one cylinder for lift and one for tilt.
Bruce
/ Will this spool work #4
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A61572)
2015 A and A...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
