will the l5740 be big enough?
/ will the l5740 be big enough? #1
ravennorth
Im looking to buy a new tractor for the main purpose of moving logs onto a small firewood processor.Most of the logs are fairly small,but in the future i will be selling some larger timber and wonder if i will be able to move those larger hardwood logs with a kubota 5740.I plan on adding a front grapple also and that will weigh about 600lbs.The tractor will be for loading and stacking not skidding.Im looking for someone with a 5740 that has done this kind of work or an experianced operator of similar sized machined to put in their two cents
/ will the l5740 be big enough? #2
If you don't get any responses here, you might try the Kubota Forum or contact NebraskaSparks or ecoslik as they recently got these tractors. I run a L5030 and M8540, but don't use a grapple.
/ will the l5740 be big enough? #3
Have you figured out how heavy your logs are likely to be? I've got a older model Kubota with an earlier version of the "8" series loaders; I think it will pick up close to the same as the new ones on a 5740... in the 2,000 lb range. Is that anywhere close to what you need to pick up (knock off the 2-300 lbs additional weight of a grapple vs. a standard bucket)?
We have done quite a bit of log work with it using forks, and it has been a workhorse. The one caution I'd give is that the width, weight and smaller front wheels of this size tractor can make them side-to-side tippy with long logs (say, 20 ft. or more) on uneven ground.
