Front-End Loader will not raise
   / will not raise #1
keithw1962
richland texas
kubota l3410
I have a Kubota L3410 with a Koyker L150 loader. The loader will not raise unless you pull the lever to tilt (left) and pull down 1/2 way to raise. It will lower but without enough power to lift the front end. Tilt works fine. Any ideas? I have already replaced the control valve and it does the same thing. Changed the hydraulic fluid and filters and rebuilt the cylinders for the lift. Thanks.
   / will not raise #2
Sometimes it’s the easy things like hoses aren’t connected right or quick disconnect aren’t setted or fitting not tight letting air pass by
   / will not raise #3
One other person had this problem and determined that one of the lift cylinders had come apart so the piston was disconnected from the rod.
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
2019 CATERPILLAR 316FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2005 PETERBILT PB335 FUEL & LUBE TRUCK (A51243)
2005 PETERBILT...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
