Will JD 72" belly mower for 4000 series fit 855?
   / Will JD 72" belly mower for 4000 series fit 855? #1
MysteryPoodle
The 72" belly mower that came with our used 855 is shot. We're looking for another and see a nice one that is for the 4500-4600-4700. Looks real similar. Think it'll work?
   / Will JD 72" belly mower for 4000 series fit 855? #2
Do a side by side comparison with a tape measure. I haven't seen either unit you have seen both.
Steve
   / Will JD 72" belly mower for 4000 series fit 855? #3
The thing to check is the gearbox ratio. Your 855 mid pto is probably 2100 rpm and the gear ratio is 1:1. Where are you located? I have a 72" JD mid mower from my 1070 that I don't use/want anymore. Such a deal could be had..
We're in Eastern Iowa. Haven't seen the one for the 4000, though -- it's on ebay. Will check the gearbox thingy (can you tell I'm not the expert on this? :D) Thank you!!!
   / Will JD 72" belly mower for 4000 series fit 855? #5
Cant answer your question but the 4510-4710's take a different 72" mower than the 4110-4410's.
It appears that the answer is "no, the mower decks from the 4000 series will not fit the 755,55,955,1070 series." The central arm on the former is offset slightly and there may be other issues. Thanks, though!
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
