Will JD 72" belly mower for 4000 series fit 855?
   / Will JD 72" belly mower for 4000 series fit 855? #1
MysteryPoodle
The 72" belly mower that came with our used 855 is shot. We're looking for another and see a nice one that is for the 4500-4600-4700. Looks real similar. Think it'll work?
   / Will JD 72" belly mower for 4000 series fit 855? #2
Do a side by side comparison with a tape measure. I haven't seen either unit you have seen both.
Steve
   / Will JD 72" belly mower for 4000 series fit 855? #3
The thing to check is the gearbox ratio. Your 855 mid pto is probably 2100 rpm and the gear ratio is 1:1. Where are you located? I have a 72" JD mid mower from my 1070 that I don't use/want anymore. Such a deal could be had..
We're in Eastern Iowa. Haven't seen the one for the 4000, though -- it's on ebay. Will check the gearbox thingy (can you tell I'm not the expert on this? :D) Thank you!!!
   / Will JD 72" belly mower for 4000 series fit 855? #5
Cant answer your question but the 4510-4710's take a different 72" mower than the 4110-4410's.
It appears that the answer is "no, the mower decks from the 4000 series will not fit the 755,55,955,1070 series." The central arm on the former is offset slightly and there may be other issues. Thanks, though!
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A53843)
30 INCH TOOTHLESS...
FLOOR AND TRANS TRANSMISSION JACKS (A53843)
FLOOR AND TRANS...
