will it take off?
   / will it take off? #831
ray66v said:
If your lucky enough to have good froward speed when you loose a tail rotor in your heli you can keep it from spinning.
There you go educating me again. I would not have guessed that was possible.
OMG I just realized how that sounded!:eek: I see you knew I mean the part about keeping it from spinning that I did not guess was possible... not the part about educating me. I am not THAT big of a narcicist to think I know EVERYTHING.
   / will it take off? #832
Knowing this crowd, someone will want to have a death match over it. But, it can be done.
As describe to me by my HCFII
From forward flight: Down on cyclic, forward on collective, While maintaining forward motion, raise cyclic as necessary to softly impact the ground, slide on the skids along the ground. The wind will keep the tail behind you.
Even more interesting, there is a way to stop rotation of the aircraft with a stuck rudder pedal (also spinning).
   / will it take off? #833
MrJimi said:
After reading all these replies?
I would suggest all of you to get a real Pilots license and read your book very good
and go from there
This whole thing has been misrepresented to all of us big time
Jim
Oh Mr. Jimi, My USAF job was instrument flying instructor on a flight simulator, I have a pilots lisc, and before I got into computers, software and training I was a physicist, briefly, before I found that a BS in Physics qualified me to be an electronics technician to a PhD in physics.
The RIGHT answer is dependent on the problem statement and precise definition of terms. That is what made the topic so interesting as well as frustrating. Depending on the problem statement and definition of terms you can argue either way, take off or no take off AND BE RIGHT. The pity was that so many folks made their own (often unwarranted and unstated) assumptions and or were close minded and filed to explore any idea contrary to their preconceived notion.
Whether or not a real airplane will take off from a real conveyor belt was never in question and is trivially obvious to even the most casual observer with a modicum of experience or physical theory (with exception of the idiot pilot on Myth Busters) but that wasn't the problem stated here, WHETHER OR NOT SOME FOLKS NOTICED IT.
Again, depending on the definitions of terms and ignoring the current state of the art in building conveyors and airgraft wheels/tires/axles, you picks your definitions and you gets your answer. Either contention can be supported, depending on your assumptions.
Somehow I am reminded of a room full of folks in a marlinespike seamanship class I taught. At break time I sent half of the class out of the room and showed the remaining half how to tie a bowline knot. Then swapped class halves and showed the other half of the class a completely different way to do it. At the next break as students were practicing the knots they had been shown there were heated discussions just short of fights in some instances as many thought the other guy was just too wrong and had to be straightened out and shown the PROPER way to tie a bowline.
Pat
   / will it take off? #834
Pat
LMAO and the best thing is knowing you did that to them on purpose.:D I would have paid money to see that. I can't for the life of me remember how to tie a bowline, but I can tie a great anchor line bowline.
   / will it take off? #835
Pat
You nailed it Pat. I've seen a number of these sorts of problems. All built with sufficient vaguaries to allow for two sides to easily form. It's all fun.
I love your bowline example!
It's all about opening the mind, which I admit sometimes I have a hard time doing.
   / will it take off? #836
Mythbusters tested the question this week and the plane took off from the conveyor just like it did from a concrete non moving runway CASE CLOSED !!
   / will it take off? #837
RobJ said:
OK you could have just said Yes, it'll fly. But why would the helo be different. What about the airboat? there's another one to ponder.
I was a convert on the plane...from no to yes after some thought.
Ever seen one of these fly?
Rob, I have not seen one of those fly, but I do have a retirement dream of mastering an RC helo (with actual rotor lift). I saw a video years back and got an impression of how difficult they are to fly, thus my wait 'til later in live where I hope to have more time on my hands.
Regarding the helo and airboat questions, I never saw the actual problem statement for either, only can assume how they were worded. Refer now to PatrickG's statement about these sorts of problems. They make for fun discussion/debate as there are intentionally two sides to argue. Another one I've been involved in is the stranded (pick your place, desert, ocean, mountain) situation where the team has to agree on the priority of a list of items they have. There is often no "correct" answer, but plenty of lively discussion/debate.
Oh, sorry for not answering you directly. Only trying to add to the vagueness of this whole thread...
BTW, if a tree falls in the woods and no one is there to hear...
   / will it take off? #838
RobS said:
I'm going to disagree on the helo. Assuming the turntable rotates at the same speed as the rotor shaft, the helo body will be spinning but the rotor will be stationary. Stationary rotor = no lift.
You got it. I can tell I know a lot less about hcops than others here, but I can dicipher reference frames and physics. Rotor motion wrt air produces lift. Here you have wings sitting still wrt atmosphere. You could get some lift if you could aim the tail rotor forward to blow over the main, but that would be modifying the chopper and it would only affect one or 2 blades at a time anyway....... Vibration and not much lift.
larry
   / will it take off? #839
There are at least 3 sides. Two of them seem unable to understand the valid points of the opposed view.
larry
   / will it take off? #840
Just to throw a stick in the ocean of theoretics:
Replace the wheels with skis (or ice skates) and ice the belt. There just went all the energy being applied to spinning up wheels, etc.
Harry K
2013 Chrysler Town and Country Van (A56859)
2013 Chrysler Town...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
17520-FL (A56857)
17520-FL (A56857)
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58216)
2012 TOP HAT...
2009 Chevrolet Colorado Crew Cab Pickup Truck (A55973)
2009 Chevrolet...
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
