will it take off?
   / will it take off? #841
Regarding the bowline... Besides there being both a cowboy bowline and a sailor bowline (AKA innie and outie) there are several variants of bowlines like the tugboat bowline, anchor bowline etc.
The reason (excuse) for my bowline example was to OPEN SOME MINDS to possibilities beyond ones own self inflicted myopia. This holds for the classroom example as well as the will it fly thing.
You may note that some of us are still doggedly (and relatively mindlessly) holding onto one position or the other, clutching to their hearts, assumptions (not necessarily stated in the problem but just plucked from somewhere) and think those of opposite persuasion are daft at best.
Guys, get over it, depending on assumptions and definitions, EITHER can be right OR wrong. Until and unless all the definitions and assumptions are teased out and agreed upon, arguing at cross purposes just wastes time.
Once you accept the MAGIC CONVEYOR the plane is doomed by the laws of physics to never take off. So long as you conveniently restate the problem in your own terms to nullify the magic conveyor (voiding the contract so to speak) you can easily make the plane take off.
This was a thought experiment not a trial such as performed by the Myth Busters whose truck pulling the "conveyor" was NOT equivalent to a MAGIC CONVEYOR. A comparison of apples to light bulbs. The one has NO BEARING on the other.
There currently exists no technology to even get close to building an actual real conveyor that will interfere with the take off of an airplane capable of taking off with no conveyor involved. So, for any realists with limited imagination and limited visualization ability who can't wrap their minds around the concept of the "MAGIC CONVEYOR", clearly the plane will always take off. For the rest of us who can grasp the concept of the "MAGIC CONVEYOR" we can see that the plane could theoretically be prohibited from taking off. This second position has absolutely nothing to do with reality and is just the result of applying simple physics to a theoretical situation to determine what would happen IF a "MAGIC CONVEYOR" could be built.
Now, as regards the helo on the turntable. If the turn table rotates at the same speed as the rotor but in opposite direction then the blade is standing still in the air mass and the relative wind over the blades is zero and so there is zero lift. Collective and cyclic pitch are not effective in the least when there is no airflow over the airfoil.
The model with the little engine mounted to the rotor has been around for decades and decades in one form or another. I have even flown a freeflight lampshade with a model airplane engine mounted vertically. You need fins inside the "duct" to cancel torque induced rotation or centrifugal force can increase to the point of disturbing fuel flow.
Pat
   / will it take off? #842
turnkey4099 said:
Just to throw a stick in the ocean of theoretics:
Replace the wheels with skis (or ice skates) and ice the belt. There just went all the energy being applied to spinning up wheels, etc.
Harry K
Ah, but are you using the special, frictionless skis or the regular ones? In physics class we always joked about the frictionless pulleys and massless string at the campus bookstore. Never found that aisle...
   / will it take off? #843
Darned, and here I thought a car on the dyno was going to go somewhere!!:confused: :confused: :confused:
   / will it take off? #844
Pat
As a young boy scout I was taught the traditional rabbit/hole method of tying a bowline (I have no idea which version). I always struggled with that method then along came a wise scoutmaster who proclaimed that you will have no time for a rabbit/hole when you are dangling off the side of a cliff. He taught a one handed version that allowed you to keep one hand on the long end of the rope at all times. Quick too. To this day, I cannot tie a bowline using the rabbit/hole but can tie one in the dark without ever removing my hands from the rope using his method.
   / will it take off? #845
Harry K
nope. wheels are an unambiguous stipulation of the original boundary conditions. But, while were playing why dont we fool with things that arent stipulated. What about gravity? no gravity no downforce on the conveyor, no traction. The wheels are skis. You can get enuf lift even sitting still for a takeoff just by blowing air over the wings. but why is there air?
larry
   / will it take off? #846
Pat
I would think yould disagree with this statement.
larry
   / will it take off? #847
Pat
Despite your long list of qualifications, certifications, and your sophistocated terms, Pat, I'm still going to disagree, even in the "Magic Conveyor" World.
The major falacy that I see in the "It will fly" camp is that they insist on imposing magical properties on the conveyor but at the same time insist on leaving the wheels of the plane in the real world in which we live.
Why are the bearings, etc. of the plane wheels subject to heat, friction, and failure, but the bearings, motors, belts, etc. of the conveyor are not?
More later about how the concept of the magic conveyor is inherently contradictory... I just got asked to make dinner.
   / will it take off? #848
Re: Mythbusters/airplane/treadmill
rback33 said:
As stated, I watched Kansas State put the kabosh to previously unbeaten Kansas last night and have not gone back to watch the episode. That will be a project for THIS evening. I had no doubt that the plane would take off though. So.. did anyone go resurrect the old thread yet? lmao Surely there must be a thousand or more "I told you so's" in order...:D
I told ya so:p
   / will it take off? #849
patrick_g:
You said "Again, depending on the definitions of terms and ignoring the current state of the art in building conveyors and airgraft wheels/tires/axles, you picks your definitions and you gets your answer. Either contention can be supported, depending on your assumptions." I am very curious what the assumptions you see that would prevent takeoff.
The original post conditions are a plane on top of a conveyer like device that rolls its surface backward at exactly the speed the plane is moving forward. This is not a complicated device, certainly not magic.
By the way, my favorite teaching bowline is collapsing a slip not (simple noose) made back from the working end after putting the working end through the loop of the noose.
Steve
   / will it take off? #850
[[[Why are the bearings, etc. of the plane wheels subject to heat, friction, and failure, but the bearings, motors, belts, etc. of the conveyor are not?]]]
[[[ I dont recall anyone saying that. I doubt that those who understand what is involved here would say it.]]] Actually tho, magical wheels would be wonderful and would assure that the magical conveyor could keep the plane on the ground forever. -- just so the wheels magicalness did not include causing them to be massless, or causing them to have a moment of inertia of zero.
larry
2020 Deere 50G (A53317)
2020 Deere 50G...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2017 Freightliner M2 106 24ft Box Truck (A56858)
2017 Freightliner...
