Will cut Bamboo Sprout in my garden?
   / Will cut Bamboo Sprout in my garden? #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
Ok heres my question. I have just cut a few bamboo stakes for my garden, fresh cuts on green bamboo. It occurred to me about halfway through the 10 or so i cut that this stuff might sprout, so will it? As a forester i know this stuff is horrible and will grow anywhere, but will it sprout from a cut stem just pushed into the ground. Thinking back now i should have cut these months ago and let them dry before i used them. So should i pull up the 4 or so i just put in?
   / Will cut Bamboo Sprout in my garden? #2
I don't know, but the stuff is sure awful...We have tons of it...:mad::(:confused2:
   / Will cut Bamboo Sprout in my garden? #3
I don't think it will sprout since it needs a rhizome in the ground. Mature canes won't sprout without the a rhizome.
I did not know if it could sprout from a bud in one of the little branches or not, like other plants like roses will do if you cut a shoot. I definitly dont have a rhizome.
Im not planting it either.
   / Will cut Bamboo Sprout in my garden? #6
Oh man if it's American bamboo, that stuff is so invasive, I've seen it push up 4" thick asphalt and sprout thru it. I had a shop for awhile in an industrial area near the train tracks, I got the place cheap cause it was a dump, the bamboo took over a large part of the property, I had it cut back and controlled pretty good with some type of poison. I sold the place 8 years ago and I see it's taking over the property again. the new owner was using a dozer on it!!
JB.
   / Will cut Bamboo Sprout in my garden? #7
We have a "japanese" bamboo here, terrible stuff.
local DEC doesn't even have a good solution, other
than injecting the rhizome with roundup while the plant
is flowering late summer.
if i cut or pull a bunch, it's interesting to put into
a fire pit! sounds like big popcorn as the cells
pop.
SO am i safe you think or should i pull the bamboo shoots out of the ground?
   / Will cut Bamboo Sprout in my garden? #9
Leave 'em in the ground. Without the rhizome, they are just fishin' poles.
Thanks for the advice, i was thinking i was safe but i did not want to take a chance and get this stuff established in my yard where i have none.
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
2013 John Deere 824K (A52128)
2013 John Deere...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
