Will a Trac-Vac 580 work with BX2350
   / Will a Trac-Vac 580 work with BX2350 #1
mentat30
Waupaca, WI
Kubota BX2350
I may have a chance to buy a used Trac-Vac 580, but I want to make sure that it will work with my BX2350. Thanks.
   / Will a Trac-Vac 580 work with BX2350 #2
The most expensive piece would be the boot to fit the deck. I've hooked several up to the BX's. Trac-Vac is one of the better makes!
   / Will a Trac-Vac 580 work with BX2350 #3
I agree,Trac-vac works great with a BX for sure.The boot will not be cheap I think I saw one on e-bay for a 54" deck new with a buy it now for $135.I run their model 880 behind my Bx2230 a love it. Good luck,check your prices this time of year used is at a higher price and demand is up always in the fall
   / Will a Trac-Vac 580 work with BX2350 #4
I have a older Trac Vac 580 on my BX24 with a 54 inch mower, works good. Much cheaper to buy the Agri Fab boot and chop it up to fit then to get the Kubota boot. I was even able to make a mount that allows me not to remove the Kubota guard to put on the trac vac boot. I will try to get some pictures tonight. And try to find that part number.
Heres the part number and website (note the website does not work using Firefox but M$ IE works)
Agri-Fab at 217-728-8388. Part number 43830
https://www.speedepart.com/index.aspx
Hey thanks everyone, somebody beat me to the vac by an hour or so. It went really cheap $200.00.
   / Will a Trac-Vac 580 work with BX2350 #6
Ah that sucks. I got mine used for 225$ deals are out there,
Good news, found a Agri Fab vac closer to home going to look at it tomorrow, its the hard sided model with a 5 hp motor and 6" intake.
   / Will a Trac-Vac 580 work with BX2350 #8
I got that same model. it is a great machine.
   / Will a Trac-Vac 580 work with BX2350 #9
Hmm maybe mine isnt a 580 then, its a 5hp briggs engine full metal cart and hood and 6 inch hoses
   / Will a Trac-Vac 580 work with BX2350 #10
Just for everybodys info, you can get a 6" boot from TSC for about $40.
You have to cut the opening to fit your deck, but its real easy.
It works pretty well. I used mine for my Trac-Vac (not sure which model) and although it clogged a few times, it beat the heck out of raking all those leaves - plus it gave me seat time on my BX2230.
-Eric
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2017 Chevrolet Express Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
