Will a spool valve with "float" function as a single acting cylinder valve?
/ Will a spool valve with "float" function as a single acting cylinder valve? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
The Fordson has only single acting hydraulics, and so I have a couple of "jacks" that would be handy to use with the two other tractors. Both of those have valves with float function.
It would seem.... that in the float position fluid from any port would be directed back to tank. But I can see problems with that thinking.
Comments?
/ Will a spool valve with "float" function as a single acting cylinder valve? #2
Re: Will a spool valve with "float" function as a single acting cylinder valve?
Use pressure to raise and float to lower. No problem.
