Will a septic tank support a BX2200?
   / Will a septic tank support a BX2200? #41
Re: Will a septic tank support a BX2200?/READ THIS
The book The Perfect Storm gives the most detailed discription of human drowning that I have ever read. I assume the same principals would apply in this case. All other factors being equal, not the way I would want to go.
Ernie
   / Will a septic tank support a BX2200? #42
When we had our system put in, (perc tests) the inspector said slow is not good, but too fast is even worse. There was a minimum and maximum drain time for the test hole (1 foot cube, filled with six inches of water) and there were two holes dug. Each hole was 6 feet deep, with a three foot step where the 1 foot cube was dug. (see CRUDE drawing) The idea was the water should leach into the soil without puddling in the bottom of the 6 foot hole.
As far as pump-outs we were told to have it done the first time in three years (1500 gallon with six people) and get an idea of the solids that were in the tank at that time. We could then adjust the schedule as needed. The idea is to catch the solids and oils in the tank. At three years we were told at our current uses (?) we could go 4 or 5 years between pumpouts. We have been sticking to three years.
Steve
   / Will a septic tank support a BX2200? #43
Additionally, in our area the price for a pumpout is in the range of $200. If the tank is hard to get to (alot of hoses) or any digging has to be done, it costs more.
Steve
   / Will a septic tank support a BX2200? #44
Steve,
What is the distance the "1 cu.ft. test hole" is from the edge? {so the water wouldn't naturally flow out the 'thin' side}
   / Will a septic tank support a BX2200? #45
Harv,
I've seen those risers before and have been toying with the idea of installing them on my system. The only thing that's held me back is concern about freezing and the frost line. I've only seen 1 or 2 installations with them, so they're not real common here, and that always makes me nervous. Could be that we haven't caught up with the technology. Could be that the technology doesn't work real great here. I'm gonna have to do some more investigation, because the risers sure are tempting. Beyond a big stinky wet spot in the back yard about the only sign I can think of is slow draining, etc. That COULD be a sign of a septic problem or, it could be a plugged line in the house.
DocHeb,
Wow! $1,000 PER FOOT? I don't blame you for re negotiation. The up side is that clay grows stuff better than this sand, so you should have a nice garden! /w3tcompact/icons/smile.gif
Will they let you put in an above ground system? Here in the Great North, there are a number of places near the rivers and lakes that are too low for good drainage. (Alternatively, they will drain into the Great North's lake or river). Since a lot of these properties already had houses with septics on them, the Health Dept allows "Pump up" systems. It works pretty much like the regular systems, except the field goes above the current grade and a lot of backfill is brought in to make a bank over the field.
ErnieB
I think Bird has one of those fancy systems. Even sprinkles his lawn. (When MINE sprinkles the lawn, you don't wanna walk on it.) I haven't heard about the ones making dry fertilizer yet. There are so many ways of doing the same job anymore that I only keep up with the ones that are showing up in local back yards. /w3tcompact/icons/smile.gif
Mike Dummond
If your tractor falls in the septic, don't worry about a thorough cleaning, just a fast hose and a quick trade will do.
/w3tcompact/icons/laugh.gif
SHF
   / Will a septic tank support a BX2200? #46
SHF, they've made a few minor changes, but you can see the new Hydro-Action that's what I have at http://www.hydro-action.com. Apparently the "standard" installation has the covers that can be opened for the treatment tank in the middle and the water tank, but has the pre-treatment/trash tank buried. I have an easy opening cover on that one, too.
Bird
   / Will a septic tank support a BX2200? #47
It's been seven years or so but as I remember it was two or three feet from the side of the test hole to the drop off of the 6 foot hole.
Steve
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
HORSE ROPING SADDLE W/ BLANKET (A58376)
HORSE ROPING...
Rhino 6200-3 (A57148)
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
SKID STEER MOUNTING PLATE (A58376)
SKID STEER...
Rhino Servis 2160 Ditch Bank Mower (A57148)
Rhino Servis 2160...
