will a cub cadet 149 move large hay bales?
   / will a cub cadet 149 move large hay bales? #1
isaaccarlson
Colfax
John Deere M, John Deere LX178, Cub Cadet 1610 hydro
I have 2 new-to-me cub cadet 149's and I am wondering if they would move large hay bales with a spear.
This is just to load and unload the truck in the shed.
   / will a cub cadet 149 move large hay bales? #2
I just googled cub cadet 149 and came up with a riding lawn mower. You have got to be kidding. The bale weighs twice what the 149 weighs!
   / will a cub cadet 149 move large hay bales? #3
If this the lawn tractor you are asking about: Cub Cadet 149, then the answer is no.
If you're talking about a different tractor, then we need the correct model number to give you an intelligent answer.
   / will a cub cadet 149 move large hay bales? #4
Maybe large hay bales is a relative term.. I think that garden tractor would have no trouble at all moving a 1x1 hay bale don't you?:laughing:
This is the same model tractor I have, but without the loader and backhoe. He says it has a lift capacity to full height of 1200 lbs and a breakout force of 2,000 lbs.
If it can move dirt around like packing peanuts, then it should be able to lift a bale of hay.
https://www.youtube.com/watch?v=URzrriQIwu4
   / will a cub cadet 149 move large hay bales? #6
That front bucket has a capacity of about two big wheelbarrows. Plus, he has the backhoe for a counter-weight.
It's still a garden tractor, and I don't think it would pick up one of my 4x5 rolls. But, you are welcome to try. Please post a link to the video. We could all use a good laugh. :D
   / will a cub cadet 149 move large hay bales? #7
How much does a large hay bale weigh? The homemade loader on the video I think would be fairly safe with maybe a 300 lb bale. Maybe 400 if you were feeling froggy. Not to mention the lift height.
Not to say the little garden tractor with the FEL is not useful. I am sure it would beat the heck out of a shovel for spreading gravel or dirt, or picking up a round of wood or a thousand things.. Just don't think it is going to be much of a big 1200 or heavier round bale mover. Sorry.
   / will a cub cadet 149 move large hay bales? #8
One needs to think a bit before asking this kind of question. No tractor can lift more than it weighs no matter how much counterweight it has. Adding too much counterweight could break an axle. Typically they can only lift about 1/4 of their bare tractor weight safely.
   / will a cub cadet 149 move large hay bales? #9
my nickel says the axles will fail as you try to life a 4x5.. even a dry loose one.
   / will a cub cadet 149 move large hay bales? #10
You didn't say what size bale.
Around here a "large bale" is 5x6 and weighs 1300 to 1500 pounds, depending on the moisture content.
This large bale weighs 1391 pounds.
Where is that lift capacity measured? The farther out from the loader arms, the less weight it will lift.
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
2002 Ford Thunderbird Convertible (A48082)
2002 Ford...
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
Pallet Fees (A50774)
