Loader Will 70 loader fit the 3005
   / Will 70 loader fit the 3005 #1
FrankX
John Deere 790
I have a 790 tractor that is damaged and needs to be replaced. I know the 7 backhoe can be transfered to the 3005. Can the 70 loader also be switched from the 790 to the 3005?
Thanks
   / Will 70 loader fit the 3005 #2
I'm not sure if it will, it seems like it should. If it were me I would sell it and put the money towards a new loader with the quick attach. The 70 is a good loader but the new ones are better IMO.
I was trying to save a few dollars, but maybe I will see what I can get for the 70 and get the 3005 with the 300. Thanks for the reply.
   / Will 70 loader fit the 3005 #4
I was surprised at what they bring used. Just start checking craigslist and e bay. I was thinking of selling my 430 for the 300.
   / Will 70 loader fit the 3005 #5
Wouldn't the standard 300 loader be a downgrade in performance?
   / Will 70 loader fit the 3005 #6
Thanks
You need to go to a dealer and look at how the 300 loader mounts to the 3005's frame.
Physically, there's little difference between your 790 and the 3005. However, the mounting hardware and such might be a sticking point...especially the hole pattern dimensions and location for the loader masts.
   / Will 70 loader fit the 3005 #7
My 430 is pretty whipped and sloppy. I like the new mounting on the 3/400 series. I've not looked at numbers but it probably is. The 430 is stout. But I would like new.
   / Will 70 loader fit the 3005 #8
I like the new method of mounting too...not sure I'd wanting to pay the $4K for a new loader though!
Why not replace the bushings/pins in your 430?
   / Will 70 loader fit the 3005 #9
I started a thread a while back about it. Dfkrug showed how to adjust the arms. I tried it and even replaced the mounts that the arms sit on. No luck. It was just abused and I think rolled on one side that tweaked it. So it's not really the pins.
   / Will 70 loader fit the 3005 #10
FrankX,
How did your JD790 get damaged? It it a complete loss? Are you going to part it out yourself or sell the whole tractor to somebody to part out? Some of the parts (i.e. front rims) are not made anymore and are hard to come by. You might make some extra $$ toward your new tractor if you part it out yourself on craigslist or ebay.
Bruce
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
