Wildkat 48" mini rock grapple on my new LS4041H
   / Wildkat 48" mini rock grapple on my new LS4041H #21
No, shipping wasn't free, but it was only $330 freight to Austin TX for both attachments.
Okay, thanks. I called them (got a recording) to get a quote for shipping.
   / Wildkat 48" mini rock grapple on my new LS4041H #22
SDEF;
Are you in an area where you cannot just tear it down and burn it?
Rick
I might be able to do that but am leery of fire. I do not have a lot of open area to safely burn, as I leave the area fairly natural and it is densely wooded, for the most part. I can have the shed totally down and loaded on a trailer in less than a day.
   / Wildkat 48" mini rock grapple on my new LS4041H #23
They are east coast U.S. and my initial contact with them was a message I left on the answering system, which was never returned... I called them the following day, mid day during business hours and had all of my questions answered.
I am in central SC and am close to their plant in NC. Shipping to my local freight terminal was $109 and only took 2 days from the time I placed the order. It is ~ $35 more to have it delivered to your address, assuming you can unload it from the truck, which I could not. Old Dominion was the freight line.
   / Wildkat 48" mini rock grapple on my new LS4041H #24
sdef, do you think that bucket is capable of doing a little digging? I.e., such as digging tree roots that are within 6" - 8" of the surface? Does it seem to be built sturdy enough for that type of work?
   / Wildkat 48" mini rock grapple on my new LS4041H #25
Oh it certainly seems sturdy enough to do that but I have not tried it yet. I think the larger question would be does the tractor have enough traction/weight to do this? I was using the BB to uproot some very large parasitic vines and had the rock grapple on the tractor using it to clean up some large, dead branches as I moved around the property. I was coming up an access lane about 3 MPH or so and the tractor was rocking forward and backward a little bit as I was traveling. I hit a rougher spot, did not have the bucket high enough and it dug a couple of inches into my hard packed clay; the tractor did not slow down a bit and the bucket probably only had a bit more of its paint scratched. I attribute this to the very strong teeth and their ability to fracture the soil ahead of the cutting bar.
Some of the vines:
I am not advocating this rock bucket as a digger, as there are purpose built tools for that. I purchased a CID stump bucket for actual digging out of roots and stumps, as it is much narrower and easier to target specific areas, where the 48" rock bucket is more of a generalized tool due to its larger width. I purchased the rock bucket to scoop up rocks as I am clearing my new property's home site and felt the 48" width would do a better job than a larger bucket and would be easier to control on a micro vs. macro basis on ground that is not flat- yet. And I wanted the grapple to move downed trees and such. But with all of this said, the rock grapple bucket is now my general- stay on the tractor bucket and will use the others only when I need a more specialized tool. So this means I will probably dig with the grapple bucket in the near future :)
But if one is comparing a regular bucket vs. this rock bucket, there is no question in my mind that this rock buck is far sturdier than a regular bucket. It does weigh ~550 pounds and most of that weight is in the bucket construction. And most earth will be in clumps and not fall through the bottom tines so it could also do double duty as a narrow, regular bucket in many circumstances. But certainly not in sandy soil.
I purchased a toothed bar to add to the regular 72" bucket to aid in digging and scooping larger areas, but have not received it yet.
Many years ago I used to purchase tools that were generalized jack-of-all-trades. But these days I purchase quality built, single purpose type tools for their better performance at the task they are designed to do. It costs more money to do it this way as evidenced by the various buckets I now have. But in the end, my tractor and I will be much better off this way and the work will be easier to accomplish with less wear and tear on the implement and tractor alike.
Attached are the CID stump digging bucket, a general 72" rock bucket and the 48" rock grapple bucket. There are less expensive stump buckets than this one, as I have found them for as little as $495 + shipping. The grapple on the narrower 48" bucket was a bonus for me and the cost was similar to the larger bucket with no grapple. So win-win in my book. Another consideration with a rock or root bucket is the amount of steel used to build one is much greater and consequently heavier than a standard type of bucket. A 66" - 72" rock or root bucket will weigh several hundred more pounds than a 48" bucket, which detracts from the FEL overall ability to lift more weight, outside of the attached buckets, and for my uses, a larger bucket is a liability in all realms of cost and performance.
John Deere (A50322)
John Deere (A50322)
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2014 Chevrolet Caprice Sedan (A55758)
2014 Chevrolet...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
2022 WESTERN STAR 49X TRIAXLE (A55745)
2022 WESTERN STAR...
