Wildkat 48" mini rock grapple on my new LS4041H
   / Wildkat 48" mini rock grapple on my new LS4041H #11
Not saying the electric over hydraulic is a not good way to go, but there is one slight advantage to the remote lever control. You can "feather" the hydraulic valve, to adjust grip strength. The electric over hydraulic is all or nothing. If your flow rate is low enough, you might be able to adjust the grip strength a bit by the dwell time of the switch contacts though. I don't think this is a big deal, but then again I don't really have enough experience with a grapple to know yet. I have had tractors with FEL's for over 20 years, but I am a grapple newbie.
James K0UA
James
We have the W.R. Long 3rd function kit on our NH TL100-A. The rocker switch on the loader joy stick will open or close the grapple as long as you depress switch. You can stop anywhere. Personally I see no need to feather anyway as not picking up eggs with it.
My 2cents worth.
Rick
   / Wildkat 48" mini rock grapple on my new LS4041H #12
Great idea using the rear remotes. Do you know what fittings were used front and rear?
I want to order them and have the hoses made for mine. Thanks. :)
   / Wildkat 48" mini rock grapple on my new LS4041H #13
I picked up my new Wildkat Attachments 48" mini rock grapple at my local freight terminal on Friday afternoon and installed it on my new LS 4041H tractor today.
I see you mention terminal delivery. Does Wildkat ship free to shipping terminals as other places do? The website seems to only refernce shipping costs to your actual location.
No, shipping wasn't free, but it was only $330 freight to Austin TX for both attachments.
   / Wildkat 48" mini rock grapple on my new LS4041H #16
I have been using this same rock grapple and WR Long 3rd function remote for a few weeks now. This grapple and bucket are awesome. I purchased it to help clear my retirement property that is very rocky and densely wooded. With the intention of first removing the required trees, I will then use the rock bucket to slowly scoop up the large rocks as I am moving forward and dump when full. I will not get to the new property clearing until November, as I am cleaning up my current home site.
I am using the bucket as a regular bucket with the grapple all of the way open (~40" open height), assuming your material will not fall through the 3" tine spacing on the bottom. It will dig easily into the ground or a wood pile. Since the 48" grapple bucket is deeper and taller than my 72" standard bucket, it will probably hold 25% - 50% more material volume, depending upon type and then secure it by closing the grapple.
I have used it to pickup and move large, downed oak limbs simply by opening the grapple and driving the bucket under the limb and then closing the grapple onto the limb, capturing it. One stop, one movement and then on the move to the dumping area in the woods. Very handy device and never have to leave the tractor to do anything with loading or securing the load.
I am moving an old, large wood pile that has old tarps intermingled into the cut firewood and the surrounding ground, which has grown over the tarps over time. It is impossible to remove the tarps by hand. I am putting the grapple bucket slightly under ground level and driving forward to get under all of the old tarps and then close the grapple and lift the bucket to remove them. Due to the large size of the tarps and small area to maneuver in, I usually have to make a couple passes into the wood pile area to get all of the tarp grasped by the grapple before lifting and backing the load out to another pile I am creating for the old tarps, that will eventually be grappled onto a trailer for a trip to the county dump. I then simply dig into the wood pile with the bucket, curl up a tiny bit and close the grapple. Works great.
With the 710# rollover BB and this grapple bucket, the vast majority of my work will be accomplished. I also have a Piranah tooth bar coming for the regular bucket and feel that with these implements, along with the CID stump bucket, I will be able to accomplish anything I need to do.
As soon as I get the wood pile moved and the old tarps loaded onto the trailer, my next project is to tear down a small, old rotting shed using the grapple bucket to push it over and then to grab the various structural components, separate them by grabbing one side and lifting, which should cause the attached corner to separate and then move to an area where I will simply cut the pieces into manageable sizes with a circular saw and reciprocating saw. I do not anticipate having to leave the tractor seat to get the shed down, separated and moved to the cutting area.
This grapple is awesome and for any purpose other than just scooping up loose material or general digging in sandy earth due to the open bottom, this grapple bucket will do far more work than a regular bucket with no grapple, although I am adding a tooth bar to the regular, closed bottom bucket, specifically for digging a wide area, if needed. And the best part is that most of the time one does not have to leave the tractor seat to grab and haul/move almost anything with the grapple bucket. It makes me much more efficient in my circumstances.
I have also used it to load cut trees into manually. During the last couple of loads that were just mainly small branches, I piled all I could get into the bucket by hand and closed the grapple to compress the branches, which made a lot more room for more branches before having to dump the load and probably saved several trips.
The remotes are skid steer 1/2" flat face made in Italy. Bucket weight is ~ 550 pounds. All movable joints have zerk fittings. The skid steer mounts mate well with my QA mounts and the bucket does not seem to have excess slop/movement noticed when driving nor using the bucket.
As another poster noted, the electric/hydraulic switch is spring loaded and only moves the grapple while one's finger is depressing it and can be stopped at any position between full open and full closed.
I am extremely pleased with this bucket design, quality and price.
   / Wildkat 48" mini rock grapple on my new LS4041H #17
I have been using this same rock grapple and WR Long 3rd function remote for a few weeks now. This grapple and bucket are awesome. I purchased it to help clear my retirement property that is very rocky and densely wooded. With the intention of first removing the required trees, I will then use the rock bucket to slowly scoop up the large rocks as I am moving forward and dump when full. I will not get to the new property clearing until November, as I am cleaning up my current home site. I am using the bucket as a regular bucket with the grapple all of the way open (~40" open height), assuming your material will not fall through the 3" tine spacing on the bottom. It will dig easily into the ground or a wood pile. Since the 48" grapple bucket is deeper and taller than my 72" standard bucket, it will probably hold 25% - 50% more material volume, depending upon type and then secure it by closing the grapple. I have used it to pickup and move large, downed oak limbs simply by opening the grapple and driving the bucket under the limb and then closing the grapple onto the limb, capturing it. One stop, one movement and then on the move to the dumping area in the woods. Very handy device and never have to leave the tractor to do anything with loading or securing the load. I am moving an old, large wood pile that has old tarps intermingled into the cut firewood and the surrounding ground, which has grown over the tarps over time. It is impossible to remove the tarps by hand. I am putting the grapple bucket slightly under ground level and driving forward to get under all of the old tarps and then close the grapple and lift the bucket to remove them. Due to the large size of the tarps and small area to maneuver in, I usually have to make a couple passes into the wood pile area to get all of the tarp grasped by the grapple before lifting and backing the load out to another pile I am creating for the old tarps, that will eventually be grappled onto a trailer for a trip to the county dump. I then simply dig into the wood pile with the bucket, curl up a tiny bit and close the grapple. Works great. With the 710# rollover BB and this grapple bucket, the vast majority of my work will be accomplished. I also have a Piranah tooth bar coming for the regular bucket and feel that with these implements, along with the CID stump bucket, I will be able to accomplish anything I need to do. As soon as I get the wood pile moved and the old tarps loaded onto the trailer, my next project is to tear down a small, old rotting shed using the grapple bucket to push it over and then to grab the various structural components, separate them by grabbing one side and lifting, which should cause the attached corner to separate and then move to an area where I will simply cut the pieces into manageable sizes with a circular saw and reciprocating saw. I do not anticipate having to leave the tractor seat to get the shed down, separated and moved to the cutting area. This grapple is awesome and for any purpose other than just scooping up loose material or general digging (with the addition of a toothed bar), this grapple bucket will do far more work than a regular bucket with no grapple. And the best part is you do not have to leave the tractor seat, most of the time. I have also used it to load cut trees into as one would a regular bucket. During the last couple of loads that were just mainly small branches, I piled all I could get into the bucket by hand and closed the grapple to compress the branches, which made a lot more room for more branches before having to dump the load and probably saved several trips. The remotes are skid steer 1/2" flat face made in Italy. Bucket weight is ~ 550 pounds. All moveable joints have zerk fittings. The skid steer mounts mate well with my QA mounts and the bucket does not seem to have excess slop/movement noticed when driving nor using the bucket. As another poster noted, the electric/hydraulic switch is spring loaded and only moves the grapple while one's finger is depressing it and can be stopped at any position between full open and full closed. I am extremely pleased with this bucket design, quality and price.
Would the wood in the old shed be of interest to people who make stuff from old "barn wood"? If so, you could either make money selling the wood or make something of it yourself?
Rick
   / Wildkat 48" mini rock grapple on my new LS4041H #18
It sounds like that grapple is really working for you.:thumbsup:
   / Wildkat 48" mini rock grapple on my new LS4041H #19
Rick
No Rick. It is old, thin plywood and 2 x 4s. Nothing special and now just junk that I have propped up on one side and still storing gasoline cans. I am getting ready to sell the house and this eyesore needs to go to the dump.
Greg
   / Wildkat 48" mini rock grapple on my new LS4041H #20
No Rick. It is old, thin plywood and 2 x 4s. Nothing special and now just junk that I have propped up on one side and still storing gasoline cans. I am getting ready to sell the house and this eyesore needs to go to the dump. Greg
SDEF;
Are you in an area where you cannot just tear it down and burn it?
Rick
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
24631 (A55853)
24631 (A55853)
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
SAMSUNG SMART REFRIGERATOR (A54757)
SAMSUNG SMART...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
