Wildkat 48" mini rock grapple on my new LS4041H
   / Wildkat 48" mini rock grapple on my new LS4041H #1
BigMoB
Central Texas - Coryell County
2013 LS R4041H, 1948 Ford 8N
I picked up my new Wildkat Attachments 48" mini rock grapple at my local freight terminal on Friday afternoon and installed it on my new LS 4041H tractor today. I bought the 3/8 hoses and fittings from Tractor Supply this morning and had it all finished by about 7:30 this evening. Running the hose from the rear remotes to the front took 13 feet of hose x 2. I used 90 degree angle fittings on the connectors for the rear remotes. This made the setup fit tight against the rear and out of the way for the 3 point lift arms. Can't wait to start using it around the homestead.:dance1:
front view of grapple.jpghoses up the side.jpgmy new wildkat rock grapple.jpgrear hose connections.jpg
   / Wildkat 48" mini rock grapple on my new LS4041H #2
Nice new toy, wish I had one. Congrats and have fun with it.:thumbsup:
   / Wildkat 48" mini rock grapple on my new LS4041H #3
Very nice. would you mind giving a review as soon as you get a chance to use it? I'm especially interested in how well it handles moving things like brush, logs, etc... in addition to rocks and boulders.
I like the heavy duty digging edge with the teeth, looks like it would come in handy breaking up some hard ground.
Price?
The grapple is listed at $900 on WildKat's web site, but I got a discount for purchasing a set of pallet forks from them at the same time...my cost was $850 plus shipping.
   / Wildkat 48" mini rock grapple on my new LS4041H #5
Review yet?
   / Wildkat 48" mini rock grapple on my new LS4041H #6
like your thoughts on the rear remotes.... gonna think that one over some....
   / Wildkat 48" mini rock grapple on my new LS4041H #7
When you run the grapple's hydraulic cylinder off the rear remotes like that, do you use the lever (for that set of remotes) to open and close the grapple? I.e., instead of having a a rocker switch on the loader handle?
   / Wildkat 48" mini rock grapple on my new LS4041H #8
Yes you use the lever for the remotes. They are manually operated when using a rocker switch they are electrical operated solenoid
   / Wildkat 48" mini rock grapple on my new LS4041H #9
Not saying the electric over hydraulic is a not good way to go, but there is one slight advantage to the remote lever control. You can "feather" the hydraulic valve, to adjust grip strength. The electric over hydraulic is all or nothing. If your flow rate is low enough, you might be able to adjust the grip strength a bit by the dwell time of the switch contacts though. I don't think this is a big deal, but then again I don't really have enough experience with a grapple to know yet. I have had tractors with FEL's for over 20 years, but I am a grapple newbie.
James K0UA
I'll give a review of this grapple setup as soon as I get a chance to use it...it's been too hot down here in Texas to do much work on my place this summer.
FMC 757 Speed Sprayer (A50121)
FMC 757 Speed...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
