Wife wants the washer and dryer raised up higher
   / Wife wants the washer and dryer raised up higher #1
kcflhrc
Kansas
2013 John Deere 3032E
So we have these front loading washer and dryer. You cant add a base to them because the base is built in, GE brand but she still wants them higher. I was thinking a 2x6 frame laid on edge with a 3/4 " plywood top and of course cross braces in between for support. Thoughts?
   / Wife wants the washer and dryer raised up higher #3
GE makes a base stand for both the washer and dryer. Can get at Lowes and Sears
That stall mat is a good idea or some kind of rubber mat, thanks.
Not for these models, the base is built in and no way too add.
   / Wife wants the washer and dryer raised up higher #6
That is what I done except with 2X4s and 3/4 floor board (advantech), cross braces at 12" centers. Had to cut hole for dryer vent and change to bottom exhaust. Was going to add front panel but two clothes baskets slide under shelf and wife is happy. White paint and some trim to finish off. They wanted around $150 each for the bases have about $50 in the shelf.
Dave
   / Wife wants the washer and dryer raised up higher #7
I second wood butcher,
washer with clothes is heavy and vibrates.brace as if it is a floor
   / Wife wants the washer and dryer raised up higher #8
Also run some rubber strips between the platform and finished floor or set on rubber mat and also fill any empty space inside of your platform with insulation or sound dampening material. The vibration and hollow space will resonate sound if not.
   / Wife wants the washer and dryer raised up higher #9
Note to self... stay with top load design when it's time to replace existing top load washer and dryer.
This is going on a concrete floor in a basement laundry room, noise isn't really a concern. Just need them higher off the ground.
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
JOHN DEERE 3 BOTTOM PLOW (A51247)
JOHN DEERE 3...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
