Width of a Kubota B2320
   / Width of a Kubota B2320 #1
amyL
woodstock, ct
kabota
Hey,
So I want to buy a Kubota B2320, the specs have the width at 45". I want the tractor to straddle 36" beds and the tires to fit down 18" paths. I think this tractor will work but what do y'all think? And is the width of a B2320 adjustable?
Thanks!
   / Width of a Kubota B2320 #2
You'd need a much wider tractor to straddle a 36" bed, maybe more along the lines of 60" wide.
   / Width of a Kubota B2320 #3
There may be 'some' adjustment to the width but not that much. In normal configuration, that machine will be 45 - 48" or so wide depending on which tires are on it. For that machine R1s will be about 10", R4s 12" and turfs 15". Fitting in the 18" paths should be doable but I can't see any way that you'll be able to straddle the 36" bed. My B3300 still only has 24" between the wheels and it's a 60" frame size.
International 656 Utility Loader Tractor (A59814)
International 656...
207275 (A52708)
207275 (A52708)
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
iDrive TDS-2010H...
5004 (A55851)
5004 (A55851)
