Wicked TOOTH BAR for Tractor Buckets!!!!
   / Wicked TOOTH BAR for Tractor Buckets!!!! #21
The bar has square holes in case someone wants to bolt it. You'd just need to make holes in your bucket.
We can also send the toothbar without the side mounting ears if requested.
Travis
If our bucket has holes already, would you you locate the holes per supplied drawing?
I'm not sure that we're quite ready to open that can o worms, but I'll run it by Ted sometime.
Travis
"Material:
Wicked Tooth Bar = AR450 Steel has a yield strength of around 175,000 lbs minimum yield. That is 75% stronger than 100K steel, and 250% stronger than 50K steel.
Piranha = "very serious steel" according to their website. Just what is very serious steel?"
thank you!
You're very welcome!
Travis
   / Wicked TOOTH BAR for Tractor Buckets!!!! #24
A Wicked Toothbar has been on the back burner for wayyyy too long.
We've had many requests...well, basically customers begging us to put a Wicked spin on a tooth bar. You know, make the meanest, strongest, most premium and capable tooth bar on the Planet.
The time is now!!
* Custom built for buckets from 48" up to 72" wide.
* AR450 Steel Construction is VERY Strong, Durable, and Abrasion Resistant. This makes our tooth bar more durable and longer lasting than any other.
* Wicked, laser cut teeth are aggressively beveled and grooved for enhanced digging and ripping ability.
* Longer, more substantial "retaining hooks" hold the bar securely to the bucket, which promotes rigidity and bucket health.
* Easy installation only requires drilling two holes, but we also include lateral holes for carriage bolts if you prefer an even more permanent and secure install.
* USA Made in our North Carolina factory!
I'll add more pics and info as these enter full production. Seven guys from the Everything Attachments Channel Group are already in line!
Travis
You couldn't have told us a few weeks earlier Travis? Just got my Piranha Tooth Bar a couple weeks ago! :(
   / Wicked TOOTH BAR for Tractor Buckets!!!! #25
Travis
Travis,
Tell Ted to just use the 60 inch Construction Attachments bucket pre-drilled holes as a guide and we will be good to go! Then you can add me to waiting list! :thumbsup:
Travis,
We'll have to work on him. :laughing:
Last I heard, they're gonna make one for our Kubota L6060 and M6-141 for some fun, necessary testing. :cool2:
Travis
Awwwwwww, man!!
Actually, the first Wicked ToothBar I sold was to a guy who already has a piranah. :thumbsup:
Travis
Wicked Toothbar Version 2 is underway, because meaner is better, right? I shared some LIVE testing footage earlier in the EA Channel Group.
Travis
   / Wicked TOOTH BAR for Tractor Buckets!!!! #29
Do you have 3-axis capability on your laser so you can cut the aggressive angle and eliminate the milling operation?
Our lasers only cut straight down. Having a multi axis may have its advantages, but, according to Ted, it still wouldn't allow us to cut a bevel as aggressive as what the mill is doing.
Travis
2016 Case 580N EP Backhoe Loader, S/N JJGN58EPLGC729072, Diesel Engine, 4 x 4, 80" Front GP Bucket, (A59076)
2016 Case 580N EP...
Kubota U35-4 (A55272)
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
DEUTZ MARATHON...
JMR Attachments QA 66" Grapple (A57149)
JMR Attachments QA...
2017 Ford Expedition SUV (A56859)
2017 Ford...
