why x585 backfires when starting
/ why x585 backfires when starting #1
fbergman
john deere x585
its fuel injection
didnt do it last fall when put away for winter .
/ why x585 backfires when starting #2
Welcome to TBN
How much backfire? just a pop? or a louder bang? (if that makes sense).
Sounds like fuel mixture.
Did you treat the gas with something like seafoam before storing over winter?
yes seafoam all the time
just a pop
/ why x585 backfires when starting #4
When my fuel injection X485 was newer, I occasionally had a pop on startup. But after running, was ok (no pop).
Recent years, no pop on startup.
Have learned a quicker (better?) start-up routine by turning over the engine for a second or three. Turn key off, then back on start again. Engine fires off in much shorter crank time with this double start plan.
Not sure why, but like it better than grinding away for a "longer time" (ha!, all of 10 seconds).
/ why x585 backfires when starting #5
Put a new spark plug in it.
/ why x585 backfires when starting #6
Has the valves been adjusted? If they are getting a bit loose, that can affect the decompression mechanism during startup.
/ why x585 backfires when starting #8
agree, esp if it's never been done previously. change the spark as mentioned too (also check if spark temp is within correct specs of engine) are you using non ethanol?
2022 EZ-GO ELITE...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
Front Tank Bracket (A64126)
Front Tank Bracket...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
