why x585 backfires when starting
   / why x585 backfires when starting #1
fbergman
john deere x585
its fuel injection
didnt do it last fall when put away for winter .
   / why x585 backfires when starting #2
Welcome to TBN
How much backfire? just a pop? or a louder bang? (if that makes sense).
Sounds like fuel mixture.
Did you treat the gas with something like seafoam before storing over winter?
yes seafoam all the time
just a pop
   / why x585 backfires when starting #4
When my fuel injection X485 was newer, I occasionally had a pop on startup. But after running, was ok (no pop).
Recent years, no pop on startup.
Have learned a quicker (better?) start-up routine by turning over the engine for a second or three. Turn key off, then back on start again. Engine fires off in much shorter crank time with this double start plan.
Not sure why, but like it better than grinding away for a "longer time" (ha!, all of 10 seconds).
   / why x585 backfires when starting #5
Put a new spark plug in it.
   / why x585 backfires when starting #6
Has the valves been adjusted? If they are getting a bit loose, that can affect the decompression mechanism during startup.
   / why x585 backfires when starting #8
agree, esp if it's never been done previously. change the spark as mentioned too (also check if spark temp is within correct specs of engine) are you using non ethanol?
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
8X 20 SHIPPING CONTAINER (A52472)
8X 20 SHIPPING...
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2012 POLAR 285BBL CRUDE TANKER TRAILER (A52472)
2012 POLAR 285BBL...
