why wont pto work
/ why wont pto work #1
simplicityguy92
why wont the pto on my hydrostatic garden tractor not work?
when i shift it turns slowly but thats it?
all the hoses and linkages are hooked up
/ why wont pto work #2
Low hydraulic fluid level?
Check hydraulic fluid filter, clogged? Replace.
Drain and replace fluid and filter if not done for a long time or if fluid looks dirty.
Mike
/ why wont pto work #3
If it's not a low fluid / bad fitler issue.. time to put a set of gauges on it, if it uses a hyd engaged clutch pack.
soundguy
/ why wont pto work #4
Check seat and brake safety switches...
/ why wont pto work #5
How did you determine that it turns slowly?
Eyeball the PTO itself?
Or is it attached to a tiller or rotary mower that not running properly?
If it is determined by connection to an implement...have you checked to see if that particular PTO shaft has a slip clutch or shear bolt?
With nothing attached and the PTO engaged, are there any unusual noises emanating from the tractor's bowels??
/ why wont pto work #6
I agree with Paul's questions. More facts and data are needed on our end. The PTO shaft is only gonna spin at 540 rpm at the reguired throttle setting. At idle it's not going to spin very fast.
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
1988 Yamaha 200hp 2-Stroke Boat Motor (A66738)
1988 Yamaha 200hp...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
