why wont pto work
/ why wont pto work #1
simplicityguy92
why wont the pto on my hydrostatic garden tractor not work?
when i shift it turns slowly but thats it?
all the hoses and linkages are hooked up
/ why wont pto work #2
Low hydraulic fluid level?
Check hydraulic fluid filter, clogged? Replace.
Drain and replace fluid and filter if not done for a long time or if fluid looks dirty.
Mike
/ why wont pto work #3
If it's not a low fluid / bad fitler issue.. time to put a set of gauges on it, if it uses a hyd engaged clutch pack.
soundguy
/ why wont pto work #4
Check seat and brake safety switches...
/ why wont pto work #5
How did you determine that it turns slowly?
Eyeball the PTO itself?
Or is it attached to a tiller or rotary mower that not running properly?
If it is determined by connection to an implement...have you checked to see if that particular PTO shaft has a slip clutch or shear bolt?
With nothing attached and the PTO engaged, are there any unusual noises emanating from the tractor's bowels??
/ why wont pto work #6
I agree with Paul's questions. More facts and data are needed on our end. The PTO shaft is only gonna spin at 540 rpm at the reguired throttle setting. At idle it's not going to spin very fast.
ROOF RACK (A68842)
ROOF RACK (A68842)
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
