Why winch?
/ Why winch? #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
A few folks have recommended that I have a winch mount added if I was having a trailer built. I can not see why this could be useful. How could this be useful on an equipment trailer?
/ Why winch?
I must be missing something. :confused:
For the off chance that the tractor breaks to the point where it is immobile? That is the only possible reason I can think of. That wouldn't be a easy load with a winch, but I suppose much easier than without one.
/ Why winch? #4
For broke down stuff, like a tractor or a car. I havehepled haul a couple cars with mechanical breakdown. Also known of folks that rebuild/restore old tractors, cars ect. Some have not run for decades, have flat or or no tires ect.
Yes, I helped "winch" a car on a trailer using chain binders. We did not have a come-along or anything, so we used what we had. Inch by inch... That was a pain in the patootsie.
/ Why winch? #5
I guess if you are never going to haul someone else's junk, Don't add it. I have hauled several vehicles for family and friends. A winch sure beats pushing. JC
/ Why winch?
Holy crap! Winches are expensive! Is there a decent hand type that can do 6k rolling?
/ Why winch? #7
Are you serious? I put a winch on my trailer and use it all the time. I have used it to rescue cars more than a dozen times. I have helped my neighbor out 3 times alone with his GM truck. Once with a transfer case, the next time a in tank fuel pump, and the last time was a starter. I have also used it to rescue a broken down tractor, pull up implements, drag pallets forward, ect. I just went with a Harbor Freight unit and its been on there for 6 or more years with no issues.
Chris
/ Why winch? #8
Just the other day I had to come-along my riding mower into my small utility trailer (wouldn't start). This is smaller stuff mind you, but the idea is the same.
Once you have a winch, you will be surprised how often you will use it. I brought home some sod once and I used my come-along to pull the pallet farther forward in the trailer. Little stuff like this is comes up all of the time.
/ Why winch? #9
As soon as people find out you have a trailer that will haul their broke down junk, they come out of the woodwork.
/ Why winch? #10
I am not so sure you need 6K rolling. I have a 4K rolling unit from HF, gave $150 for it, and its pulled up a full size Dodge 1500, a Chevy 1500, a diesel Suburban 2500, a Tahoe, and numerous full size cars. It has also pulled up a 8N with a 6' Bush Hog on it that was dragging due to the tractor not running and no way to lift it.
Chris
/ Why winch? #11
You can even buy a smaller winch and use a snatch block to double the pull. This is a pulley you put on the object being pulled--you run the winch cable through the pulley, then anchor the hook end back on the trailer. Now there's effectively 2 lines pulling on the object, so you get twice the line pull. So if your winch can only pull 1500 pounds direct pull, it now can pull 3000--albeit at half the speed...
And yes the winch can be quite handy. I too have recovered cars, loaded my box blade on the trailer with it....
/ Why winch? #12
That was a big plus even has a 10' remote on the trailer I own now. Had to go out and winch up a some cars in my younger days by hand. Even with a few guys it's not very fun Late at night on the side of the road. Not much to it with one.
Carey
/ Why winch? #13
I too use mine all the time, I have a 8000 lbs winch mounted inside a tool box along with a battery, the battery is hooked up so it charges anytime hooked to the truck. Also I keep all my chains and straps in it out of the weather. One other thing I added was a wireless remote for the winch and use it instead of the wired controller, makes loading a vehicle a one person job.
/ Why winch? #14
Wireless Really now thats Cool. And I thought I was big time with two Ports. One towards the front and the other in the dove tail :thumbsup:
Carey
/ Why winch? #15
I have a "portable" elec. winch & a center tie-down hook on my 16' trailer, have loaded a "dead" JD 1020 w/loader with it.
My smaller trailers have hand winches. ~~ grnspot110
/ Why winch? #16
Hud-son has a very tough hand winch, I own one and use it for everything. It is not one of the cheapo's you'll find at the big type stores.
/ Why winch? #17
Get the Winch, well worth it!!!!!!
I used a hand winch on my first trailer, then come-alongs, and I am talking quality $150 come-alongs, not junk, for years. both worked OK, but were a lot of work! Now I have a winch, I will never look back, one of the best things I ever did!!!
My winch is a 3500 lb Warn, it was called the Pull-Pack, not sure if they still make it. It works great, I do sometimes use a snatch block for heavy stuff with frozen brakes etc.
It is mounted to a 2 inch draw bar. I welded a trailer hitch to my trailer, and ran wires to the rear of my truck with a connector. I store the winch inside, just slide it in the hitch and connect the connector and I am ready to go.
/ Why winch? #18
If you are having a trailer built, at the very least spring for an extra $50 and have a reinforcement added for a possible future winch install...will be a lot harder and more expensive to do after the fact.
/ Why winch? #19
/ Why winch? #20
I have a winch for the back of my tow car, it allows me to tow through the front of both my current trailers for loading.
I guess, even when I am quite able to drive a vehicle onto a trailer sometimes it is just safer to winch it up.
I currently have five manual winches, chain hoists and comealong types as well as winding types alongside the electric for the back of the car. It will soon be back up by a small electro-hydralic crane that will allow me to lift as well as pull and also to raise the pulling point higher by using a pulley from the crane hook.
I should really seek therapy for my winch habit.:laughing:
Bobcat 873 (A60462)
Bobcat 873 (A60462)
Case IH Early Riser 1230 (A60462)
Case IH Early...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2015 John Deere 5075E (A60462)
2015 John Deere...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
