Why winch?
/ Why winch? #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
A few folks have recommended that I have a winch mount added if I was having a trailer built. I can not see why this could be useful. How could this be useful on an equipment trailer?
/ Why winch?
I must be missing something. :confused:
For the off chance that the tractor breaks to the point where it is immobile? That is the only possible reason I can think of. That wouldn't be a easy load with a winch, but I suppose much easier than without one.
/ Why winch? #4
For broke down stuff, like a tractor or a car. I havehepled haul a couple cars with mechanical breakdown. Also known of folks that rebuild/restore old tractors, cars ect. Some have not run for decades, have flat or or no tires ect.
Yes, I helped "winch" a car on a trailer using chain binders. We did not have a come-along or anything, so we used what we had. Inch by inch... That was a pain in the patootsie.
/ Why winch? #5
I guess if you are never going to haul someone else's junk, Don't add it. I have hauled several vehicles for family and friends. A winch sure beats pushing. JC
/ Why winch?
Holy crap! Winches are expensive! Is there a decent hand type that can do 6k rolling?
/ Why winch? #7
Are you serious? I put a winch on my trailer and use it all the time. I have used it to rescue cars more than a dozen times. I have helped my neighbor out 3 times alone with his GM truck. Once with a transfer case, the next time a in tank fuel pump, and the last time was a starter. I have also used it to rescue a broken down tractor, pull up implements, drag pallets forward, ect. I just went with a Harbor Freight unit and its been on there for 6 or more years with no issues.
Chris
/ Why winch? #8
Just the other day I had to come-along my riding mower into my small utility trailer (wouldn't start). This is smaller stuff mind you, but the idea is the same.
Once you have a winch, you will be surprised how often you will use it. I brought home some sod once and I used my come-along to pull the pallet farther forward in the trailer. Little stuff like this is comes up all of the time.
/ Why winch? #9
As soon as people find out you have a trailer that will haul their broke down junk, they come out of the woodwork.
/ Why winch? #10
I am not so sure you need 6K rolling. I have a 4K rolling unit from HF, gave $150 for it, and its pulled up a full size Dodge 1500, a Chevy 1500, a diesel Suburban 2500, a Tahoe, and numerous full size cars. It has also pulled up a 8N with a 6' Bush Hog on it that was dragging due to the tractor not running and no way to lift it.
Chris
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
Case IH True Tandem 340 (A60462)
Case IH True...
2011 CIRCLE M  35 GOOSENECK (A60736)
2011 CIRCLE M 35...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
