Why the whine?
/ Why the whine? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I'd say 6-8 weeks ago, there was a thread about HSTs and the topic of the whine was mentioned, as is often the case. Someone gave a nice, brief explanation of the internal design that causes HSTs to whine. I cannot find this post, and was wondering if anyone else has it or can recall such an explanation.
Thank you
/ Why the whine? #2
Thank you
The transmission pump/torque converter operates at a very high rpm and the oil really moves at a high gallon per minute/foot per second speed through small piping and control valves. The cooling fan adds to the noise as well.
/ Why the whine? #4
Sorry.. wrong whine. But just incase you get other whining... :laughing:
/ Why the whine? #5
Which Kubota HST models have a torque converters?
/ Why the whine? #6
Perhaps some good cheese to go with that whine will help :laughing:
My L3130 has some whine, more pronounced after it has been worked a bit when climbing hill.
/ Why the whine? #7
It's not unlike the noise you hear when running water. Just much higher pressure and viscosity. Very normal.
/ Why the whine? #9
Loenz,
Your 20 yrs in the hyd repair field experience is showing again......:thumbdown:
/ Why the whine? #10
All of them, torque converters are what make automatic gearboxes and HSTs possible :)
Kubota uses Piston Pump/Motor Combo Units.....The noise you hear is the oil running thru the piston rotating groups......the whine increases with pressure/velocity/torque......and/or hyd oil viscosity
Though it's a torque converter of sorts, it works on a different principle than your automatic transmission...Hydrostatic transmissions
The direction of flow and displacement is changed internally in the pump using a swashplate design (controlled by your for/rev pedals moving a lever on HST).....NOT from "small piping and control valves"....
All this is normal in Piston Pump Design.......:thumbsup:
/ Why the whine? #12
wdchyd said:
Kubota uses Piston Pump/Motor Combo Units.....The noise you hear is the oil running thru the piston rotating groups......the whine increases with pressure/velocity/torque......and/or hyd oil viscosity...
That will learn me for taking my lecturers advice. Goes to show experience counts tenfold over book learning
Thanks for the clarification!
/ Why the whine? #13
a hst inst like a torque converter. the only way there alike is the fact the both use low pressure hi flow hydraulics but the concepts are different.
UNUSED PARBREAK GB232-79" HYD GRAPPLE BUCKET (A65055)
UNUSED PARBREAK...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2017 Isuzu NPR-HD 14ft. Stakebody Flatbed Truck (A64556)
2017 Isuzu NPR-HD...
E-Z TRAIL 1020 GRAIN CART (A64278)
E-Z TRAIL 1020...
LOT OF GRAIN BIN LADDERS (A64278)
LOT OF GRAIN BIN...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
