Why the whine?
/ Why the whine? #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
I'd say 6-8 weeks ago, there was a thread about HSTs and the topic of the whine was mentioned, as is often the case. Someone gave a nice, brief explanation of the internal design that causes HSTs to whine. I cannot find this post, and was wondering if anyone else has it or can recall such an explanation.
Thank you
/ Why the whine? #2
Thank you
The transmission pump/torque converter operates at a very high rpm and the oil really moves at a high gallon per minute/foot per second speed through small piping and control valves. The cooling fan adds to the noise as well.
/ Why the whine? #4
Sorry.. wrong whine. But just incase you get other whining... :laughing:
/ Why the whine? #5
Which Kubota HST models have a torque converters?
/ Why the whine? #6
Perhaps some good cheese to go with that whine will help :laughing:
My L3130 has some whine, more pronounced after it has been worked a bit when climbing hill.
/ Why the whine? #7
It's not unlike the noise you hear when running water. Just much higher pressure and viscosity. Very normal.
/ Why the whine? #9
Loenz,
Your 20 yrs in the hyd repair field experience is showing again......:thumbdown:
/ Why the whine? #10
All of them, torque converters are what make automatic gearboxes and HSTs possible :)
Kubota uses Piston Pump/Motor Combo Units.....The noise you hear is the oil running thru the piston rotating groups......the whine increases with pressure/velocity/torque......and/or hyd oil viscosity
Though it's a torque converter of sorts, it works on a different principle than your automatic transmission...Hydrostatic transmissions
The direction of flow and displacement is changed internally in the pump using a swashplate design (controlled by your for/rev pedals moving a lever on HST).....NOT from "small piping and control valves"....
All this is normal in Piston Pump Design.......:thumbsup:
/ Why the whine? #12
wdchyd said:
Kubota uses Piston Pump/Motor Combo Units.....The noise you hear is the oil running thru the piston rotating groups......the whine increases with pressure/velocity/torque......and/or hyd oil viscosity...
That will learn me for taking my lecturers advice. Goes to show experience counts tenfold over book learning
Thanks for the clarification!
/ Why the whine? #13
a hst inst like a torque converter. the only way there alike is the fact the both use low pressure hi flow hydraulics but the concepts are different.
2022 EZ-GO ELITE...
2024 SCHWING SP 750-15 T-4 (A67737)
2024 SCHWING SP...
2149 (A65055)
2149 (A65055)
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
