Why the wheels?
/ Why the wheels? #3
They look like they came from a giant mutant erector set.
/ Why the wheels? #4
I would venture a guess that they are used to cut drainage channels in wet fields. I have seen similar wheels on four wheelers for that purpose.
/ Why the wheels? #5
Around here they are used to spray levee's in rice fields. Occasionally they also will be used when spraying a crop such as soybeans after the plants have bushed out enough to prevent the passage of a normal tractor tire without crop damage.
/ Why the wheels? #6
They look like they would give awesome traction and less soil compaction than a normal width tire.
/ Why the wheels? #7
They could be Amish and not able to use rubber tires.
/ Why the wheels? #9
/ Why the wheels? #11
Back a bunch of years I had an 80 cc off road bike, locking the front brake and reving the engine did the coolest job of trenching, running water finished the job.
Also it was fun!
/ Why the wheels? #15
Three uses for them. Some times used in slow high crop work but mainly rice fields and draining low spots from fields in the spring. I have a friend that had a set on his 4020.
/ Why the wheels? #16
I've seen tree nursery's use them. Its so expensive to maintain sapling crops thus the smaller the field the more economical it is and a minimal track means more area to grow crops.
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
