Why SUDT???
/ Why SUDT??? #41
<snip>
I've only every seen one private label oil that meets SUDT specs, and its about $15 cheaper for a 5-gal bucket. Whatever it is, I don't get the impression that they're exactly making a windfall on it.
Lately on the Forum where this should be taking place there were several posts about Chevron's clone.
http://www.tractorbynet.com/forums/oil-fuel-lubricants/143437-sudt-udt-thf-story-5.html#post1712453
http://www.tractorbynet.com/forums/oil-fuel-lubricants/143437-sudt-udt-thf-story.html
Messick - could you share your knowledge of the private label oil?
My main concern is that I do not like being tied to 1 and only 1 supplier, especially when it seems that other options are viable.
I can understand requirements for "special fluids", I've got a 2009 Jetta TDI which requires a special engine oil spec.
But apparently there are many people buying new Kubota's only to find out they require special fluids ONLY sold by Kubota AND the dealer they purchased from does not have the fluids.
In the case of my diesel car many dealers have been found putting in the wrong, cheaper oil. Even though they carry the more expensive type. But at least it is available and from several labels. "What oil do I use?" READ FIRST BEFORE ASKING - TDIClub Forums
In the case of my diesel tractor I checked the oil, it was low, I needed a quart. NOONE I could find carries SUDT within a 45 minute, one way drive, so I was "forced" too either drive 1.5 hours to get a a quart or order mail order and pay shipping charges. UDT is carried at the local auto stores.
So bottom line was I ordered mail-order (5 gal.pail) from this place called Messicks and it took a day to get to me.
I'd like more options.
Plus Kubota's D$%^ stuff is transparent and hard to read on the stick.
/ Why SUDT??? #42
"There there baby, that man won't convince me to use anything but the good stuff in you." pat pat pat
The man ask a intelligent question and gets this silly post. Only opinions and no good answer.
get ready, here comes the explanation.
Fascinating...491 reads, 27 replies, not one empirical statement regarding the difference between SUDT and any other Hydralic Fluid.
Even the Kubota dealer that replied could not state what makes SUDT better than any other Hydr. Fluid.
I'm not asking these questions to pass judgement on anyone who purchases SUDT.
Simply wondering why SUDT is better? Hydr. Fluid is a very thin viscosity petroleum product. Unless I'm missing something the oil is not lubricating like a motor oil does.
So again...any empirical statements regrading why SUDT?
The fact that an owners manual states you should use it COULD just be simple marketing.
First off all oil is not the same, PERIOD. Kubota oil is designed and engineered by their engineers to their specifications. This holds true to virtually ALL lubricating fluids regardless of manufacturer. Kubota sets the spec for their fluids based on system requirements for performance, longevity, and reliability. Once the spec is set they solicit a manufacture who can build the oil from the ground up to meet their specifications. This all starts with the base stock oil, who or where has the best base stock available to make the foundation for the oil? What country or oil field has the most built in additives that meet the spec? Once a base oil is finally selected then the source for the additive package comes into play. Whom makes the additives needed to meet the spec? Lubrizol, Chevron? Then blending and testing come into play, once the product is shown to meet the requirements then the manufacturing comes in.
Most tractor supply branded oils are made by Citgo, they are the absolute worst lubricant manufacture on the planet. You could not give me a trailer load of there product. So keep running it. :rolleyes:
SUDT is a multiviscosity , anti wear, extended service, multi function hydraulic fluid.
I am all for saving money where one can, and I practice it by purchasing the correct fluids for all my equipment.
I run Lubrication Engineers 10w30 CH rated oil in the engine year round. I use Lubrication engineers Monolec 703 80w90 gear oil in my front diff. I run Kubota SUDT in the hydro system, along with all Kubota filters.
1- Where did the base stock come from?
2- Where did the additive package come from, and who designed it?
3- Will the additive package and base stock work together to meet a specification or exceed it?
4- What group of oil is best suited to the application?
5- Some oils should never be interchanged. Some can be successfully interchanged.
I have yet to see any dealer that "I deal with" (car, truck, tractor) know anything even remotely close to the truth about lubricants.
So, in short, you are comparing apples to rocks. So keep eating the rocks, they are the same as apples. :D
/ Why SUDT??? #43
I think Tug Hill makes a good point. Does anyone really know why SUDT is better?
Without having an expertise in chemistry, no, probably no one here really KNOWS if/why it's better. So, without having all of the technical knowledge one must possess to truly know, it's best to go with what the manufacturer recommends. I am very much in the camp of thinking of it as cheap insurance.
If I were a fluids expert and had years and years of knowledge and experience, I very well might conclude on my own that it's not worth the expense. But, until then, I will not pretend to know more about it than the people who designed the transmission.
It certainly very well could be just a marketing decision for Kubota say "USE SUDT ONLY!!" But, that's not a coin I'm willing to toss.
/ Why SUDT??? #46
What I've observed on several tractor forums over the course of 4 yrs is that SUDT has never caused any HST failures or problems and in most cases either eliminated or quieted the whine in an HST that previously used UDT and/or an aftermarket brand of a UDT equivalent.
There's your empirical data, Tug Hill. HST's run quieter with SUDT. That has been consistently reported by a huge number of owners.
/ Why SUDT??? #47
Using anything but SUDT is becomming more of a risk all the time. Stuff like the RTV's and ZD's are very picky about their trans fluids and don't run as well with other stuff. The service intervals on the newer equipment are also speciflying SUDT only. The oil changes are now twice as long as what they had been when they okayed UDT or SUDT. If your not running SUDT, I'd be changing the transmission oil twice as often.
My RTV-900 manual says SUDT or UDT. I've used UDT for the first two changes since that's what I have sitting in the shed. I don't know, maybe it would have been quieter last winter if I used UDT, but I never noticed a problem.
/ Why SUDT??? #48
I'd say that HST fluid has a much harder job to do than an engine oil does.
Correct, oil is first and foremost a lubricant. It cheats as it has coolant to help it. HST fluid has a much wider range of functions - it's a coolant, lubricant, and hydraulic fluid.
/ Why SUDT??? #49
Interesting tidbit regarding warranty: because another VERY WELL KNOWN company for doing what may be deemed as similar (though not by me) is Harley Davidson. Talk about extreme mark-up!
A court case was heard and ruled on setting precident on this matter, of having to use a manufacturer consumable (engine oil in this case)... The court deemed that any (enter oil weight/viscosity here) is able to be used without voiding manufacturer warranty. The courts further ruled that if any manufacturer were to require a particular consumable (fluid) to be used to maintain their own specified warranty, that the manufacturer must provide the fluid to the owner at no cost.
I understand this is not the same as SUDT/UDT vs. other hydraulic oil debate, but I could see someone making the arguement that if you find a SUDT rated fluid, although performance may not be the same, it legally cannot void your warranty.
Search this link for "Magnuson Moss" HARLEY OIL DEBATE states essentially: "an OEM cannot require a consumer to use an OEM part or fluid in order to maintain warranty coverage unless that part or fluid is provided free of charge."
Before the flaming begins... I use SUDT, and plan to continue... I cannot speak to any differences between Kubota brand SUDT fluids, and other brand SUDT fluids, but my post is simply to ease the mind of someone thinking the 'fluid' would void any warranty on their valuable purchase.
2008 BOBCAT T320 SKID STEER (A62129)
2008 BOBCAT T320...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
DEUTZ MARATHON...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
