Why so much positive camber ?
/ Why so much positive camber ? #1
Arky217
Hartford, AR
Kubota L4200
I have a Kubota L4200; from the first day I got it, I've wondered why it has so much positive camber on the front wheels. (I tend to notice these things since I was a front end mechanic in what seems like was a previous life).
As measured from the middle of the tire's sidewall top to bottom, it has 1.125" positive camber on each side. That's a lot.
I haven't looked any other tractors to compare it to, but I wonder if all tractors or all Kubota tractors are like that. Maybe it's a 4wd thing.
Anyone notice that on your tractor, and/or have any idea why they're made like that ?
/ Why so much positive camber ? #2
Found this from Wikipedia on Camber angle.
"Off-road vehicles such as agricultural tractors generally use positive camber. In such vehicles, the positive camber angle helps to achieve a lower steering effort"
David Kb7uns
/ Why so much positive camber ? #3
David Kb7uns
That's what I've understood as well. I see it on alot of tractors. Everyting I've ever had leaves a trail in the gravel from the front tires, including, tractors, quads and utility vehicles. It can he hard on tires though.
/ Why so much positive camber ? #4
My guess would be that it has to do with reducing the strain on the wheel/axle bearings.
With no or negative camber, the tire contact patch would be further away from the bearing therefore creating more leverage/load.
i can see how important it would be, especially with a fully loaded FEL
/ Why so much positive camber ? #5
Another thought I have heard expressed is that under load, the axle tends to straighten out slightly so the tire ground contact is improved.
Sounds like a bit of stretch to me - no pun intended.
/ Why so much positive camber ? #6
Positive camber helps with turning.:)
/ Why so much positive camber ? #7
I don't believe that the camber is adjustable on the vintage Yanmar 2wd or 4wd front axle.
The toe-in is adjustable in the typical fashion via a threaded collar on the tie rod.
Adjustment is 1/8 to 3/8" IN. Most everyone sets it at a quarter inch toe-in.
rScotty
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
70in. Skid Steer Root Rake (A65640)
70in. Skid Steer...
SILVER EAGLE CST20W 5TH WHEEL DOLLY (A64277)
SILVER EAGLE...
Used 20' Container (A62679)
Used 20' Container...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
4 Bottom Plow (A65640)
