Why oh why
/ Why oh why #41
Have you put a pressure gauge on the system and check what pressure does it put out when you try to lift the tractor with just the lift cylinder down pressure?
I see two hoses and it is the same loader that I had on my TC33D. It had down pressure, just not enough to lift the front tires.
/ Why oh why #42
I saw it's a double acting cylinder on the OP's picture and that's why I was thinking. Just not enough force to lift the tractor but does have down force.
With putting the pressure gauge, I trying to rule out any bad or improperly installed seals.
/ Why oh why
I'm satisfied that the other NH owners on here and the 3 I went to look at have no downward force and the loader works as it should.
/ Why oh why
It showed on pressure gauge 2,450 plus pounds
/ Why oh why
2,450 plus lbs
/ Why oh why
Sure, but just like it can't lift 3000 pounds, maybe it can't lift itself.
Maybe it has a weak pump. Internal leaks. Valve issue.
gauge shows 2,450 plus lbs
/ Why oh why #49
Then it's working as it should and just doesn't have the force to lift the front of the tractor.
/ Why oh why #50
Have a TC34DA, FEL will lift front end with boom all the way to cylinder stops with bucket flat on ground or curled with cutting edge sitting on ground. Don't think I have ever tried with just bucket curl
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2012 Dodge Avenger Sedan (A59231)
2012 Dodge Avenger...
Toro Sand Pro (A56859)
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2005 Peterbilt 387 with Wet Kit (A61307)
2005 Peterbilt 387...
2017 Peterbilt 320 T/A E-Z Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Peterbilt 320...
