Why not sugar water in tires instead of beet juice?
   / Why not sugar water in tires instead of beet juice? #91
A few years ago I bought a 1990 b8200 kubota with out loaded rear tires. Idk how someone used this thing for 30+yrs with out loaded rear tires. It was almost un useable.
I have owned a 1957 Ford with calcium in the rear tires for about 9yrs with out a single issue.
To each his own. I bought a B8200 new in 1985 and it never had loaded tires and it was never a problem for me. Had a loader and used it for everything I needed it for! Sold it about 5 years ago and the guy who bought it used it for a couple of months before bought it. He didn't/hasn't loaded the tires either.
   / Why not sugar water in tires instead of beet juice? #92
$3-4 a gallon installed is typical for "beet juice" and there's a calculator for figuring how much is needed by tire size. I would steer clear of calcium chloride as it's known to be caustic and rust rims from inside out which is why it's rarely used anymore. As has been mentioned before sugar water can become caustic as well. "Beet juice" is not sugar water, it's the leftover syrupy liquid after the sugar has been removed. Plain water can work as long as you never see freezing temps, south Florida maybe, but can cause corrosion as well. I wouldn't use antifreeze as the environmental concerns wouldn't sit well with me. Windshield washer fluid can be a cheap option with slightly less environmental concerns and sure wouldn't want to spring a leak in the garden or crop field.
I hear you on environmental concerns, but it's probably not a problem.
People don't use regular old green poisonous ethylene glycol radiator antifreeze to mix with water for loading tires. It does look like Gatorade and it has a sweet attractive tasted.....But if it leaks, it kills growing things. Plus any animal that drinks it will die - although not easily. Kids are at risk.
RV antifreeze - the pink fluid stuff you put in pipes for winter storage - is what people use to mix with water for loading tires. It is propylene glycol. It has all the temperature & mixing advantages as the green radiator fluid, costs about the same, sits on the next shelf at the auto parts place, and best of all it is not-poisonous. In fact it is used in food prep.
I don't load tires myself. More trouble than it's worth for what I do.
rScotty
   / Why not sugar water in tires instead of beet juice? #93
I also prefer steel to liquid for weight. If one set isn't enough, get longer bolts and add a second or third set.
Biggest mistake I made was letting 1300 pounds of weights go with a tractor I sold!
David from jax
   / Why not sugar water in tires instead of beet juice? #94
SF82,
This thread grew some new legs.
I bought a 55 gal drum of 92% propylene glycol ( non poisonous glycol ) in 2019 for $476 delivered for a non tractor related project . Cost was $8.76/ gal so not really cost competitive with RimGuard and propylene glycol at a specific gravity of 1.03 is just 3% ( 8.595 Lbs/ gal ) heavier than water ( 8.345 Lbs/ gal ) so a weight dis-advantage over RimGuard at 10.7 Lbs / gal.
The Propylene Glycol can be diluted from 92% ( freeze pt greater than -60'F ) to 50% solution with freeze pt of -29'F to roughly equal the RimGuard freeze pt of -35F but again you lose considerable weight advantage when using a product other than beet juice.
   / Why not sugar water in tires instead of beet juice? #95
I bought an Oliver tractor with 38" tires at an auction years ago. It worked great but had been used for tractor pulls and the rear tires were unknowingly filled with water. When they froze I drove about 100 yards and the tubes got pulverized by the ice frozen solid inside the tires and the tractor returned to the yard with the tires flat on one position only. With every revolution of the tires there was a deep blip when the tractor flopped down like driving over a stump.
Water might be OK for tire ballast in the Caribbean but not in Canada.
I'm 20 miles north of Louisiana. We never use straight water here. But, your machine was hauled a lot so I imagine it would be straight water. You could have let some out and seen what it was. Most people that buy tractors probably have a way to freeze something.
   / Why not sugar water in tires instead of beet juice? #96
rScotty
When the RV antifreeze (pink stuff) goes on sale, that's the time to stock up. Its normally $1 or $2 cheaper than the beet juice.
Yes, propylene glycol is found in gummy bears, Swedish Fish, most salad dressings, BBQ sauces, and much more.
For organic farms, the Sierra RV/Marine antifreeze of the propylene glycol is used. Its both pet safe and safer for the soil. This works well in the engine cooling system. Costs a little more than regular antifreeze too.
For the OP question, just take a glass of sugar water, place it in the coldest freezer and come back in 72 hours. If it's rock solid frozen, then don't use it for the tractor. But, it you boil the sugar in the water to infuse it, run the test again. Then with the same solution test it a week later. If it's not over 40% frozen, you could have a viable solution. The question then is, how long would the solution hold up for.
When water freezes, the water molecules arrange themselves into special patterns - this is why we can sometimes see neat patterns in water crystals. If there is something like sugar mixed into the water (an 'impurity'), then it is harder for the water molecules to form the proper patterns. The sugar molecules are not the same shape or size as the water molecules are, so they don't fit into the ice crystals, even though they do fit nicely into the liquid water. Because of this, it's actually harder to freeze liquids like juice or soda than plain water - you have to get them colder before they will freeze. This is why these 'impure' liquids did not freeze as quickly as plain water. In chemistry, this is called 'freezing point depression'.
Department of Physics
University of Illinois at Urbana-Champaign
We can look at the freezing points of certain liquids. Click on the (F) in the chart to get the cold temp to display. Look for non-flammable and non-corrosive.
Liquids - Freezing and Melting Points
Linseed oil down to -4 could be a solution. Cost wise is very high per gallon.
Propylene glycol down to -76, (RV/Marine Antifreeze) and mixes well with water.
Other than Beet Juice, what else works?
Corn oil at $12 average per gallon. Yet it could go rancid over a few years.
Canola oil at $30 average per gallon. Will last years.
Refined Soy oil that can work is a mere $14.41 per gallon.
Refined White Sorghum syrup malt, will not crystallize, is a mere $44 per gallon.
Finding a really good non-freeze non-corrosive liquid to fill in tractor tires being cost effective, Beet juice and RV/Marine antifreeze is really hard to beat price per gallon.
   / Why not sugar water in tires instead of beet juice? #97
SF82,
Love the comparison here.
For SCUT and CUT tractors not in the deep freeze north, the RV/Marine Antifreeze works just fine. The weight would work for these smaller machines. I get the RV/Marine antifreeze for a mere $3 or less per gallon at Walmart, Farm-n-Fleet, etc. already diluted to the -40F. My area lowest record temps is not greater than -30F.
Going the 1-gallon jug route already diluted is a huge savings over RimGuard. Plus most places will only offer 'service' to install the RimGuard, so the additional cost vs. doing it yourself at home with the RV/Marine PG.
A 55-gallon metal drum alone already has a higher cost. 55-gallon Plastic drum is a tad less. The 1-gallon and 5-gallon buckets of RV/Marine PG is priced minimally for the container thanks to mass production.
We know both products work really well for Ag applications. It's the overall price point people have with hobby farms and homesteads where RV/Marine PG comes out ahead. For larger Ag farms, RimGuard is very attractive.
I only use the filled rear tires for snow removal on a 2WD tractor. I don't plant winter crops nor harvest them out in the mid-west plains. Likewise, some mid-west operations are still harvesting corn before the heavy snows arrive. Those would be the operations needing RimGuard.
The OP is filling tires on a YM2310, its a CUT nearly the size of my machine.
His tires are not as big as an 8N. Bet he's doing the same operations I do too for a homestead. :)
   / Why not sugar water in tires instead of beet juice? #98
I can get BioBallast at $3.50/gallon. My concern is if/when I need to transfer the fluid out or get a leak...
I need about 160 gallons between my two rear tires. That's a LOT of 1 gallon jugs! Have you noticed a trend of when (or where) it goes on sale?
   / Why not sugar water in tires instead of beet juice? #99
WOW 160 gallons. Those are huge tires. I have a compact tractor so its about 1/2 that. I got a shed with a shelving unit to load up the jugs.
The trend to buy is after the first good freeze. By then most RV'ers and boats dry docked for the winter have already been winterized. Over the late Fall, cabin owners with shallow wells and umps will use it till they close up for the season. Its this time to buy it.
   / Why not sugar water in tires instead of beet juice? #100
What are you finding in a price per gallon, for the RV?
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
2012 Chevrolet Traverse SUV (A55853)
2012 Chevrolet...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
