why not hose clamps
   / why not hose clamps #21
Wouldn't the liability issues only matter if the ROPS failed (e.g., collapsed)? If someone got injured or killed and the ROPS didn't collapse, would it matter if the ROPS had a work light welded to it (assuming the work light didn't injure the operator)?
Even then it doesnt matter. it ONLY matters if you think someone wants to sue a manufacture for something YOU did.
If you simply take responsibility for your own actions, and are comfortable operating the equipment you modified, then there are ZERO liability issues.
Yes, There is another out there that believes in a perfect world. Sadly, there are just not enough of us. We are greatly out numbered.
   / why not hose clamps #23
Soundguy pointed me in the direction of hose clamps and I have used one to relocate my SMV sign to the ROPS - away from behind the seat where it made it hard for me to access snowblower controls.
It has worked nicely.
   / why not hose clamps #24
I like em.. I've used hose clamps to hold lamps to an old loader fram with round posts..
soundguy
   / why not hose clamps #25
Just for thought; If you put a "u" bolt around the ROPS; and attach a light to the "u" bolt; isn't that a modifacation to the ROPS. You "may" have stressed the ROPS at the point of the "u" bolt. See; a lawyer can do anything they want. When the tractor rolled over, the attached light and "u" bolt snapped which hit my client and caused injury. How could the jury argue? I guess anything you touch on your tractor could be a liability.
   / why not hose clamps #26
The only hitch there is that some of those non-drill mods are dealer approved.. IE.. adding a canopy.. which on my fords, either 'sandwhiches' the rops.. or uses u-bolts...
soundguy
   / why not hose clamps #27
The curiousity question becomes: Is "Dealer approved" Ford, or any manufacturer approved, and would Ford or 'other' stand behind it as an approver modification in court?
   / why not hose clamps #28
I'd guess it would depend on who spec'ed the parts.. IE.. if the kits for the canopies are a manufacturer supplied item.. I'd have to say ( as a nonlawyer ) that they are 'defacto' approved. Can't say as to the aftermarket stuff, unless the manufacturer maintains an approved list of equipment.. IE.. I've seen some tell you what backhoe you can or cannot use, with respect to warranty.. etc..
soundguy
   / why not hose clamps #29
If "dealer" installs it; dealer would probably be held liable; if you install it; you will probably be held liable. ie- how tight did you torque the bolts?
   / why not hose clamps #30
I don't think such liability applies to the consumer just the dealer/Manufacturer.
I'm not in the business of building or selling tractors therefore such rules don't apply to me.
49205 (A55788)
49205 (A55788)
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
2004 Woodchuck Altec AT37G 37ft Insulated Rover Bucket Lift (A55852)
2004 Woodchuck...
1999 Ford Econoline E-150 Cargo Van (A55852)
1999 Ford...
2020 CATERPILLAR 416 F2 BACKHOE (A52707)
2020 CATERPILLAR...
2025 Yongkang Liqian LQVC 2 Passenger Electric Car (A55853)
2025 Yongkang...
