why not hose clamps
/ why not hose clamps
Even then it doesnt matter. it ONLY matters if you think someone wants to sue a manufacture for something YOU did.
If you simply take responsibility for your own actions, and are comfortable operating the equipment you modified, then there are ZERO liability issues.
Yes, There is another out there that believes in a perfect world. Sadly, there are just not enough of us. We are greatly out numbered.
/ why not hose clamps #23
Soundguy pointed me in the direction of hose clamps and I have used one to relocate my SMV sign to the ROPS - away from behind the seat where it made it hard for me to access snowblower controls.
It has worked nicely.
/ why not hose clamps #24
I like em.. I've used hose clamps to hold lamps to an old loader fram with round posts..
soundguy
/ why not hose clamps #25
Just for thought; If you put a "u" bolt around the ROPS; and attach a light to the "u" bolt; isn't that a modifacation to the ROPS. You "may" have stressed the ROPS at the point of the "u" bolt. See; a lawyer can do anything they want. When the tractor rolled over, the attached light and "u" bolt snapped which hit my client and caused injury. How could the jury argue? I guess anything you touch on your tractor could be a liability.
/ why not hose clamps #26
The only hitch there is that some of those non-drill mods are dealer approved.. IE.. adding a canopy.. which on my fords, either 'sandwhiches' the rops.. or uses u-bolts...
soundguy
/ why not hose clamps #27
The curiousity question becomes: Is "Dealer approved" Ford, or any manufacturer approved, and would Ford or 'other' stand behind it as an approver modification in court?
/ why not hose clamps #28
I'd guess it would depend on who spec'ed the parts.. IE.. if the kits for the canopies are a manufacturer supplied item.. I'd have to say ( as a nonlawyer ) that they are 'defacto' approved. Can't say as to the aftermarket stuff, unless the manufacturer maintains an approved list of equipment.. IE.. I've seen some tell you what backhoe you can or cannot use, with respect to warranty.. etc..
soundguy
/ why not hose clamps #29
If "dealer" installs it; dealer would probably be held liable; if you install it; you will probably be held liable. ie- how tight did you torque the bolts?
/ why not hose clamps #30
I don't think such liability applies to the consumer just the dealer/Manufacturer.
I'm not in the business of building or selling tractors therefore such rules don't apply to me.
/ why not hose clamps #31
I wouldn't think that hose clamps would be as durable as a U bolt. I don't see a U bolt causing the ROPS to fail, but I could foresee someone being injured if some part of their body hit either the end of the hose clamp or the protruding end of the bolts in a rollover.
I could also see where the light assembly could come loose in a rollover and cause injury--or you could run into a low limb and have the light assembly break off and hit you. It might not be life threatening, but if it cost someone an eye, then there's the liability--as one example.
Neither manufacturers nor dealers want to assume any more risk of liability than they already have for something that they didn't engineer and sell in the first place.
My lights are bolted through factory holes in the ROPS. The benefit of having the lights outweighs my concerns about who to sue if I roll over. Now if I could just figure out how to keep the lights from drawing bugs--
/ why not hose clamps #32
To keep bugs from lights- do NOT turn them on! LOL
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
2019 PALOMINO COLUMBUS 5TH WHEEL (A63569)
2019 PALOMINO...
IRGC40 High-End Mini Golf Cart (A64047)
IRGC40 High-End...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
