Why is this hydraulic control leaking on my Ford 3000?
   / Why is this hydraulic control leaking on my Ford 3000? #1
gelbviehguy
MOUNT STERLING
Bought this aftermarket remote setup and everything works fine,but it has a little leak out the back. See pics. All the o-rings are there and the bolts are tight. I went to take it off a minute ago and when I got all 4 bolts out it went "pop" and let some hydraulic fluid out. I thought the o-rings took the place of a gasket?
   / Why is this hydraulic control leaking on my Ford 3000? #2
Assuming those o-rings are new since you said it was a new setup, I guess I would inspect them with a magnifying glass to check for nicks and replace any that are defective. You may also want to clean up some of those sealing metal sealing surfaces with a little steel wool or wire brush to make sure there is no corrosion particles from giving you a good seal.
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
Mini Skid-Steer Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
