Why is this hydraulic control leaking on my Ford 3000?
   / Why is this hydraulic control leaking on my Ford 3000? #1
gelbviehguy
MOUNT STERLING
Bought this aftermarket remote setup and everything works fine,but it has a little leak out the back. See pics. All the o-rings are there and the bolts are tight. I went to take it off a minute ago and when I got all 4 bolts out it went "pop" and let some hydraulic fluid out. I thought the o-rings took the place of a gasket?
   / Why is this hydraulic control leaking on my Ford 3000? #2
Assuming those o-rings are new since you said it was a new setup, I guess I would inspect them with a magnifying glass to check for nicks and replace any that are defective. You may also want to clean up some of those sealing metal sealing surfaces with a little steel wool or wire brush to make sure there is no corrosion particles from giving you a good seal.
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
Deere 310L (A53317)
Deere 310L (A53317)
