Why is this hard? Hydraulic sizing frustration
   / Why is this hard? Hydraulic sizing frustration #21
The shepherd's hook looking thing? That isn't a lever, that is at the tank breather with a loop to prevent rain from getting in. It does look like something you'd pull but it you take a second look it is held on with a hose clamp and although painted, it is made out of a soft, rubbery material.
In #4 right above the vent. It looks like a spool with maybe a U bracket with a pin going thru it. What is that for?
That is the first to three cable actuated spool valves. A detent can be screwed into the large, silver plug's hole. The first two you can do not have detents and the last one, off camera on top has a detent for continous flow. Kioti officially list only two spool for remotes but three will fit and work with longer bolts thanks to Fastenall.
Here is the set up in the stripped-down cab.
   / Why is this hard? Hydraulic sizing frustration #23
Thanks!!!!
   / Why is this hard? Hydraulic sizing frustration #24
Hi All....and Eric - next time you're harassed by a banjo or similar exotic fitting,
just have a look at those guys :
MyFUI
maybe they can help :)
Decorative Turtle Statue (A55758)
Decorative Turtle...
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54757)
DIXIE CHOPPER...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2015 Acura MDX SUV (A55758)
2015 Acura MDX SUV...
pressure washer (A55973)
pressure washer...
