Why is this hard? Hydraulic sizing frustration
   / Why is this hard? Hydraulic sizing frustration #21
The shepherd's hook looking thing? That isn't a lever, that is at the tank breather with a loop to prevent rain from getting in. It does look like something you'd pull but it you take a second look it is held on with a hose clamp and although painted, it is made out of a soft, rubbery material.
In #4 right above the vent. It looks like a spool with maybe a U bracket with a pin going thru it. What is that for?
That is the first to three cable actuated spool valves. A detent can be screwed into the large, silver plug's hole. The first two you can do not have detents and the last one, off camera on top has a detent for continous flow. Kioti officially list only two spool for remotes but three will fit and work with longer bolts thanks to Fastenall.
Here is the set up in the stripped-down cab.
   / Why is this hard? Hydraulic sizing frustration #23
Thanks!!!!
   / Why is this hard? Hydraulic sizing frustration #24
Hi All....and Eric - next time you're harassed by a banjo or similar exotic fitting,
just have a look at those guys :
MyFUI
maybe they can help :)
2019 CATERPILLAR 336GC EXCAVATOR (A52706)
2019 CATERPILLAR...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2012 BMW 328i Coupe (A55853)
2012 BMW 328i...
