v8dave
Platinum Member
I've made a few comments over the past year that I bought a B7610 instead of a B7800 because it would fit alongside my shop. Well, here are a few photos to show the available space.
When I bought the Kubota the shop wasn't yet started. But the dirt pad was finished. I had the plans made up to build as big a shop as I could get on the pad. This only allowed a 5' pass way alongside the shop. And, to get that I had to put in a retaining wall. The opposite side of the shop is as steep as shown here, but the house blocks the access to front.
I bought the B7610 because it was specified as 46.3" wide. The B7800 is 7.5" wider on the spec sheet. I didn't know two important things at the time. 1) the specified width is with the rear tread set at it's narrowest position--nobody delivers tractors set at the narow axle width, and 2) the retracted backhoe outriggers are wider than the tractor--and the spec sheets don't show this.
I bought the B7610 because it was specified at ~4' wide. It isn't that narrow but it does fit through. But, only because the retaining wall is a block wall that "leans" back and provides an extra 5" clearance at the top over the base. The wide outriggers need this distance. If I'd bought the B7800 thinking I could just squeeze through, I'd have been in big trouble with it's bigger backhoe. And, I wouldn't have know this until the shop was finished five months later. Sometimes you just happen to make the right decisions. . . .
Of course I could drive through the shop. But, to do that I'd have to move some project stuff and at times that isn't too convenient to do.
First photo, going in from front side of shop. I have to raise the loader to clear the wall as I turn in (both ends).
