3-Point Hitch Why I can't plow
   / Why I can't plow #31
I've got 80 acres and the only area that has EVER been plowed is the old homestead garden plot - around 100' x 150'. So when we moved onto the property in '82 the garden plot had been "broken" last in about '52. Thirty years - but the Troy Bilt Horse did a great job and we had a garden for about eight years - until all the local indigenous inhabitants - pocket gophers, deer, raccoons , chipmunks, skunk etc, etc found the garden. Then it was simply a lost cause - they did not want to share - they wanted it all. We quit with the garden.
Five years later I got a wild hair - till up a couple acres - plant corn - freeze corn - make shine out of what we didn't eat fresh or freeze.
I bought a very heavy duty Pittsburg single bottom moldboard plow. Took a while but finally got the hang of how to set it up and I proceeded to plow up about an acre. Thats as far as I went - that turned sod REFUSED to be broken down any further. My poor little Ford 1710 4WD and my Land Pride disk harrow were just to light to do the job.
I finally smoothed the plowed acre with my LPGS - scarifiers down - multiple passes. - Kubota M6040. No longer interested in growing corn. Just a whole lot easier to buy what I need at the "store".
   / Why I can't plow #32
It gives retired folks something to do that they enjoy "if" the local critters aren't robbing all of it, I had a big garden a few years ago and like you the local deer, bears and everything else destroyed it, I go the stand for everything May to October and frozen stuff the rest of the time..
   / Why I can't plow #33
I've made old horse drawn ploughs , brinly sleeve hitch plows , also made my own out of some plate steel. They all worked good. Lots of posts one here have good ideas etc;on setting them up. One thing not mentioned is that you need to keep the plough as level as possible. The top pin on a category [ 0 ] TPH should be 12" higher then the drawn pins. On a category [ 1 ] TPH the top pin has to be 15 1/2 " higher then the draw pins. Also it's best if the top link pin is straight up from the 3 pth draw pins. This will keep you plough level when lifted up or in the ground ploughing.
This is a pic of the plough that I made complete that I used on a old MF 10 and a old horse drawn plough used on my Kubota bx with cat 1 TPH
   / Why I can't plow
For all of you guys big thank you . It giving me ideas to work on my adjustment, set up and mouting. Thanks to you I will make it works sooner or later.
Thank you.
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2018 Ford F-550 (A55973)
2018 Ford F-550...
BOBCAT SKID FORK ATTACHMENT (A56857)
BOBCAT SKID FORK...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
