Why I Bought a PowerTrac 425
   / Why I Bought a PowerTrac 425
Forks
Bringing load of bricks (85 lbs each) to wall site at my home.
PJ
Box Blade
Back view of box blade – ¼ inch steel through out.
PJ
Box Blade
Top view with teeth in up position and box blade tilted back.
PJ
Box Blade
Pushing with box blade to fill in trench line.
PJ
Box Blade
Teeth in digging position – very hard packed ground. Made couple of passes in two directions to get soil loosened up and level.
PJ
Box Blade
Pushing into piles – used box blade as much pushing as I did pulling.
PJ
Box Blade
Started to level ground in preparation for cement. Getting into tight areas is no problem for an articulated tractor.
PJ
Mower
Mowing along brick wall – going around objects is very easy with the articulated 425.
PJ
Mower
Ease in cleaning the underside – many use a water hose, others a putty knife, I use both.
PJ
Large Bucket
Back filled dirt on steep slope prior to placing stone boulders for retaining wall at friends home. Very first project for 425 and I.
PJ
WEILER S350 SKIDDER (A60429)
WEILER S350...
40' CONTAINER (A52706)
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
