Why do helicopters "chop"?
/ Why do helicopters "chop"? #61
Re: Why do helicopters \"chop\"?
Rob, I didn't think the tip of the helicopter rotor or the tip of an airplane propeller ever get to super sonic speeds. I was always under the impression that if it did, terrible things would happen. That's why there are no supersonic airplanes powered by propellers. So the chop noise couldn't be a sonic boom, could it?
Interesting reading on supersonic propellers.
/ Why do helicopters "chop"? #62
Neat website Dave. I can't answer whether or not a helicopter rotor travels at supersonic speeds only can guess what the shock wave might do. You are right though, shock waves can be very destructive.
Again, I'm recalling very vague memories of college but there are all sorts of strange phenomena that occur in trans-sonic flight. Wing shapes for sub-sonic flight don't work at supersonic speeds. Airflow can be quite different. The distinctive delta shape to fighter jets and the Concorde have to do this all of this. The swing wing fighters are an attempt to handle both sub-sonic and super-sonic aerodynamics.
The challenges continue inside the jet engines. There is a type of jet engine called a ram-jet that basically has no moving parts. Once moving through the air the compression of the air due to ram shape and super-sonic effects provide the the necessary compression for combustion. Fuel is dumped in which burns continuously and expands as it exits providing thrust. I have no idea if these engines actually exist, only that they make for challenging engineering class problems. For as poorly as I did in some of these classes, I'm surprised I have such interest /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #63
"Rob, I didn't think the tip of the helicopter rotor or the tip of an airplane propeller ever get to super sonic speeds. "
Actually they do, that is what causes the machine gun staccato of an airplane propeller at max output. The tips reach supersonic speed and the noise you hear is mini sonic booms, shock waves. Prop speeds (RPM) and propeller diameters on conventional aircraft are designed to limit it to efficient sub sonic speeds but during a dive or at full power tips speeds just barely reach super sonic speeds in SOME aircraft, most notably high speed prop aircraft like WWII iron etc. The whole propeller is not supersonic, just the very tip and the shock wave it produces is a sonic boom. Imagine a Mustang in a power dive at say 450 MPH and the prop with a tip speed in the range of 500 MPH, the combined speeds put it beyond supersonic, it is not direct additive, you have to do trig and what not I am not in the mood to do now or calculus
Active noise cancelling headsets are actually designed to cancel the propeller noise more than the engine noise. They are very effective. Light Speed is a well known brand of active headsets.
Most percieved noise from a passing propeller aircraft on the ground is from the prop, not the engine, same with a helicopter and you are correct about the doppler and phase shift causing the pulsating chopping sound. Helicopters are a flying nightmare. Their top speeds being limited by the speed of the advancing blade thus attempts of late to reduce the work load of the blades and allow them to operate at low RPM and use wings or other means to provide lift at higher speeds--the Carter Copter is an example--do a search for that subject.
Just came back from another P&W school, work on airplanes every day.
Well, that was my post for the week, got to get some primer on my recently sand blasted bumpers, the little Toy is getting some serious upgrades in preparation for high gas prices this summer. Line-X on the bumpers and on the side rock nerfs, on top of the bed cap and in the bed, a new TJM front bumper with Warn Winch, headers and exhaust, thinking on a supercharger but I would have to make it myself, new wheels and tires-slightly larger, heavy duty torsion bars and some other cool stuff just cuz such as an air locker from ARB upfront and an auto locker to replace the worn out thingy in the rear. It should still get it's 25-35 MPG so I cannot go huge on tires and I don't like that look anyway. Finally got Rancho to hand over 4 new RS9000 shocks since the others were long worn out and they just could not understand what Lifetime Warranty meant but I finally explained it to them and they agreed. Told them I would be back in touch for another set in 10 years or so /forums/images/graemlins/laugh.gif. I am going for 1 million miles, may not live long enough. Installed a diff drop to restore CV angles on my slightly lifted Tundra after a boot clamp came loose, looks like that cured the problem for the long term. Had to install a heavy duty LSD in the rear to control the new power to the ground, don't know if the wheels go supersonic or not Poor little 'botas are all lonely and forgotten covered in dust. Maybe they need propane injection /forums/images/graemlins/grin.gif. --or maybe not. Well, out'a here, take care /forums/images/graemlins/smile.gif. J
/ Why do helicopters "chop"? #64
Sounds like you're having fun J, thanks for your insights /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #65
/ Why do helicopters "chop"? #66
Very neat. So they had to have fuel going up through the shaft and out through the rotor blade to the little engines? Alos, it said they had a small 1hp engine that would initially spin the rotor to get the tips up to 50MPH speed in order for the ram jets to start working. So, it really had 3 engines.
/ Why do helicopters "chop"? #67
</font><font color="blue" class="small">( Please explain what you meant by "body interaction". )</font>
I left the world of fluid dynamics 7 years ago, but here goes:
If you throw a rock in a lake, the you can see the concentric circles of water travels away from where the rock hit the water. Those ripples are actually the information, or the disturbance, propagating through the water. Now if you poke a stick int the water and move it slowly in one direction, you can see that the distance between the waves in front of the stick become compressed, while the distance between the waves behind the stick expands. This is the doppler effect. What happens if you move the stick faster than those waves can travel? Information from the distrubance from the stick can't travel faster than the stick, since this information travels at a same speed when the disturbance was stationary. So, all of the information travelling foward from the stick basically accumalates in fornt of the stick, since the disturbance in front of the stick is being pushed foward along with the stick. This what happens when you travel at supersonic speed, the air in front of the wing is undisturbed, but the wing is travelling faster than the information from the disturbance cause by the wing can travel forward. So, in a very short distance, the air goes from stationary to a supersonic disturbance, so somewhere in between the air is travelling at sonic speed, which means this is the maximum speed, given the current conditions, that information can travel in forward direction. This sonic region is marked by the sonic boom, where there is significant change in pressure, thus the noise, between the subsonic & supersonic regions. This mach wave not only sits in front of the wing, but radiates above and below the wing where it begins to spread as the transitition from subsonic to supersonic flow becomes less severe. Far away the the wing, all of the flow is subsonic, but the information of this disturbance radiates through the atmosphere, so the sonic boom can be heard at a long distance. Since the helicopter blade effectively travels slower as the blade get closer to the rotor, the mach wave also travels inward towards the subsonic region. Now much of this inward disturbance is dissipated blade istelf, but some of this wave still travels downward & inward to intersect the body(& boom) of the helicopter. At near subsonic speeds, the mach wave reflections won't be that severe, but will in general provide some interference waves to make life in the helicopter slightly more hospitable.
The misses is on the phone with her mother tonight, so I had to go it alone. I hope I didn't disappoint anyone. /forums/images/graemlins/grin.gif
<font color="white"> ... </font> /
<font color="white"> . </font> /
| <==< <font color="white">...... </font> How shocking /forums/images/graemlins/ooo.gif
<font color="white"> . </font> \
<font color="white"> ... </font> \
P.S. For any fluid dynamists out there, the water example was for illustration purposes only, so no flaming. /forums/images/graemlins/wink.gif
/ Why do helicopters "chop"? #68
Interesting Story:
When we first moved to Texas, my wife told me she had no idea where here new job was located. So we took a look on the map, and I drove her to Bell Helicopter facility in Hurst, while she navigated. After we got back to our apartment, I declared that I had just taken her to Bell and back. /forums/images/graemlins/tongue.gif
Well, at least she thought is was funny. /forums/images/graemlins/wink.gif
/ Why do helicopters "chop"? #69
</font><font color="blue" class="small">( So what's the answer? The chop is caused by the the blade tips reaching super-sonic speeds. The sonic boom that is created is your chop. )</font>
Dave, after doing my research, I am going to say that helicopter rotors do not reach super-sonic speeds. They are in the transonic range and may approach .8 Mach, but no faster. The rotor tips are designed to reduce the pre-sonic shockwaves much like vortex generators on fixed wing aircraft. The following link to a short explanation by a Hughes Research Lab engineer is very specific in noting the blade tips are designed with an "ax-head" to reduce vibrations at "near sonic" speeds.
Helo Rotor Tip Design
I also talked briefly to our Sikorsky S76 lead instructor at our training facility who said a helo blade tip at supersonic speeds would probably self-destruct because of its simple airfoil shape.
As to some WWII prop airplane's props reaching supersonic speeds as Trescrows pointed out, that has happened, but it is not something done on a regular basis. Prior to reaching supersonic speed a simple airfoil like a prop will experience a severe loss of efficiency much like an aircraft wing losing lift as the sound barrier is approached. Since the prop's movement is perpendicular to the flow of air over the airplane, the speed of the prop and speed of the air cannot be added directly to produce a summative quantity exceeding the speed of sound.
I believe the chop of a helo rotor is nothing more than the peaks and valleys of air and sound waves which travel much like an electrical AC sinewave. The chops are the peaks passing our position and the changing pitch of the sound is the doppler effect. The volume of the sound depends on the pitch angle of the blades to our position (over us, to our side, approaching, or departing). The interference of the tail rotor and the volume of other interference waves certainly reduce the amount of chop we hear.
I just can't accept that sonic booms play any part in the sound we hear from a helicopter. /forums/images/graemlins/smirk.gif
/ Why do helicopters "chop"? #70
<font color="blue"> For any fluid dynamists out there, the water example was for illustration purposes only, so no flaming </font>
Hey, no problem if you'll stay off my case for comparing shock waves to cavitation /forums/images/graemlins/shocked.gif
Thanks for the information Dave, I may not sleep any better but it will have nothing to do with helicopter chop /forums/images/graemlins/smile.gif
That cleared up a lot of stuff I did not think about or clearly understand before. Cool stuff!
/ Why do helicopters "chop"? #72
Transonic flow is the region defined between 0.8 & 1.2 Mach. It is assumed for transonic flow that shocks exist in this regime due to acceleration of the flow due to the varying shape of the object. Technically, supersonic flow is anytime the flow is greater than Mach 1.0, but in the common usage, it is normally considered to be supersonic when the mach number is greater than 1.2. The 1.2 number is what you will see if you are reading papers discussing supersonic flow. I was using the term supersonic as > 1.0 for conceptual purposes, since this is TBN and not an AIAA conference. Transonic rotor blades generate shocks.
Transonic Helicopter Noise
/ Why do helicopters "chop"? #73
<font color="blue">I was using the term supersonic as > 1.0 for conceptual purposes, since this is TBN and not an AIAA conference. </font>
Oh, sure, talk down to the tractor guys.... just kidding. /forums/images/graemlins/grin.gif I appreciate the time people with training take when people like me ask questions. Thanks. /forums/images/graemlins/laugh.gif /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #74
</font><font color="blue" class="small">( I'm getting in on this late, but here's an explaination that I was given some time back. Most of the chop-chop comes from the sound of the tail rotor reflected of the bottom of the main rotor baldes! )</font>
You know, I read the same thing once.. that helicopter noise could be reduced dramatically by shrouding the rear rotor in some way. I gather they have almost silent copters now? (No jokes about Black Helicopters please.) /forums/images/graemlins/smile.gif
Anyone know what the current state-of-the-art is? I don't know for a fact that it's true that some of them are almost silent. But it made sense that the interaction of the main rotor and the rear rotor was the cause of the buffeting "chop" sound.
As an aside, a friend of mine used to say "Helicopters *always* mean bad news!" Someone is hurt, being rushed to a hospital, some kind of miltary action, some criminal on the run, some natural disaster, and so on. I think he exaggerated, but it was an amusing thought. I'm certain that to a person stranded inside enemy lines, the sound of the chopper is the sweetest in the world!
Bob
/ Why do helicopters "chop"? #75
hello to all,
i was a helicopter mechanic in the army in korea in 1951,52.
i was attached to the 8063 MASH. the army sent me to school
in SAN MARCOS TX. in 1951, where i learned about fixed wing
aircraft, and helicopters.
the other person had it correct. the tip speed of the blade is breaking
the sound barrier, and this is what causes the chop,chop sound.
we had BELL H13D, and E models in korea, and they were used to fly
wounded to the MASH unit. i flew with the pilots sometimes, but i was
never comfortable in one. i knew too many things about all of the
mechanical parts, and the stress that was put on them during flight,
and this worried me. i am 75 years old in two months, and have never
flown in a "chopper" since i was in the army.
accordionman
william l. brown
wright city, mo.
/ Why do helicopters "chop"? #76
</font><font color="blue" class="small">( Transonic rotor blades generate shocks. )</font>
Dave, no matter what it may sound like, I think you and I are agreeing more than it might appear. Certainly, there are air flows around a transonic object that exceed the speed of sound. To produce these flows and their associated noise, the rotor only has to approach speeds near 0.8 Mach. /forums/images/graemlins/cool.gif
Thanks for the link to the paper regarding modelling of the noise. It appears that for a particular size and shape of rotor, the noise is very predictable and capable of being accurately modelled. /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #77
</font><font color="blue" class="small">( We had one circling nearby this morning. )</font>
Circling, huh? Dude, that don't sound so good. Are the neighbors in trouble?
Steve
/ Why do helicopters "chop"? #78
Gosh guys, I almost understood part of what you were saying and didn't want to feel like the only person with nothing to contribute. So, which type of chopper makes the loudest chop, the gear model or the hydrostatic model? /forums/images/graemlins/confused.gif
MarkV
/ Why do helicopters "chop"? #79
<font color="blue"> So, which type of chopper makes the loudest chop, the gear model or the hydrostatic model </font>
It's gotta be the one with the R1 tires regardless of transmission. Everyone knows R4s are tuned for transonic speeds. Now which oil for supersonic tractoring, conventional or synthetic /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #80
Thank you all for answering something I have wondered about for many years. And for those of you that learned this stuff while wearing a military uniform in service of this country, a BIG THANK YOU!
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59912)
2014 HYUNDAI...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
