Who's better at estimating slope angles?
/ Who's better at estimating slope angles? #21
I still use my "Puckerometer". It's old and wrinkly but still puckers up at just the right time. Requires no service or maintenance. Just an occasional cleaning.
/ Who's better at estimating slope angles? #22
I just hate the ones that are so bad that you leave little swirls pulled up in the seat vinyl.
/ Who's better at estimating slope angles? #23
Wow. :) Couple of interesting things here. I have a Tiltmeter, too. For those of us that didn't grow up on a tractor or don't run one all day at work, they are very useful.
I found that I didn't get uncomfortable until 15 degrees. Of course, if you know the terrain and there are no holes or rocks, and the FEL is low and/or empty, the tractor just isn't going to spontaneously fall over at 15 degrees!
I did an interesting experiment. My uncle, an experienced tractor operator, put my Tiltmeter on his tractor. I walked behind him while he drove across several slopes on his farm, and he made note of the degrees of tilt.
I had previously driven-- or tried to! :eek: -- these same slopes, but chickened out on some.
We learned two things. Some slopes looked like they were steeper inclines than they actually were. Others looked less steep than they actually were! So our senses of balance and sight are not 100% reliable for degrees of slope.
Also, when I followed behind the tractor on foot as he drove some of the slopes that I wasn't comfortable on, I could see that the tractor was not anywhere remotely near the tipping point. (Again, this assumes flat terrain, no holes or rocks, of course.)
So I've now become more comfortable at 15-20 degrees. One thing I learned that has helped is to put my hand on the fender on the low side and lock my elbow. This extra bit of bracing makes me feel more stable and is useful on slopes where there is little to no danger but I wasn't 100% comfortable.
I do the same thing! I have the tiltmeter but I lock my elbo on thelow side too. I would say I'm good to about 20 degrees but don't push it much after that.
Rob
/ Who's better at estimating slope angles? #24
Kind of like saying all Baby boomers, x generation, y gen, and so on act in a certain way just because they were born between a certain span of years.
Each man is his own.(or woman) You define yourself and you educate yourself. Just because you are over x years old doesn't mean you will take more chances or react in a certain way.
Yes and no, the middle ear, responsible for balance, is filled with tubes and bones and as we get older our balance, like our hearing, diminishes. So youngsters have the edge over us old timers.
Rob
/ Who's better at estimating slope angles? #25
While I outright reject broad generalizations, I accept the effect age has had on me personally. There are areas on one of our farms, I have to leave to my sons. I mow the areas with which I am comfortable and then swap tractors with one of them ages 31 and 41 as I simply no longer trust my ability on those areas.
/ Who's better at estimating slope angles? #26
Now that is just plain special ..... Thanks for the laugh.:)
/ Who's better at estimating slope angles? #27
Given that 20 degrees is in the roll over zone I will not knowingly get to 20 degrees. 15 is pushing it for me. In my case the difference in the amount of grass cut at 10 degree and 15 is minimal. As is from 15 to 20 degrees. The ground I mow were I really pay attention could very well have a hole, hunk of wood, or rock that was not there the last time I mowed. If I am mowing at 15 degrees a rock, hunk of wood, or hole could be just enough to cause a roll over. Not likely though.
But rolling the tractor is not worth cutting an extra bit of grass. It is just grass. :D
Making myself more comfortable on a slope is not my goal. Not rolling the tractor is my goal. :laughing:
Later,
Dan
/ Who's better at estimating slope angles? #28
A question; when your mowing do you watch for irregularities in the slope or do you watch the slope meter. How much time is spent on each as the tractor is moving?:D
/ Who's better at estimating slope angles? #29
I think 20 degrees is a good limit. It's less than halfway to the 45 degree mark, but it's enough that you won't have to stay off of 40% of your property for fear of some spontaneous, physics-defying rollover! :D
My goal is not to make myself comfortable on dangerous slopes, but to make myself comfortable on non-dangerous slopes, (or should I say less dangerous slopes), and to know the difference.
This is complicated by too many factors to cover here (FEL position and load, wet vs. dry grass, woodchuck holes, tire type and wheel spacing, etc., etc.) but these must all be taken into account by each operator, too.
The degrees of tilt we're discussing here are arbitrary. My first time on a tractor, I was uncomfortable at what was probably 5 degrees. So should I never go on a slope that exceeds that? That's silly. I want to understand the limits of the machine, and myself, and operate safely within those limits.
I also searched for and bought a used ROPS bar for my tractor because it did not come with one. All these things together add up to safe(r) operation... in my humble opinion, anyway.
Also, for Egon... I don't keep the Tiltmeter on my tractor. I used it to learn the degrees of slope on the parts of my property that aren't flat, and then I operate with that knowledge from then on. My uncle did the same.
Staring a tiltmeter rather than paying attention to what you're doing will only help you verify for the EMTs the exact degrees of tilt you were at just before you rolled! :laughing:
/ Who's better at estimating slope angles? #30
what are the tractors rated to? Are they still getting oil in the engine?
/ Who's better at estimating slope angles? #31
I have often wondered that... as I back up a steep hill to mow.
/ Who's better at estimating slope angles? #32
It's not a problem, the sumps sit very low in the pan and some engines have a 'step' where the oil collects in a restricted portion.
Racing engines are , of course, different. They often run dry lubrication where the oil sits in a reservoir outside the engine itself and is pumped through it. It's not uncommon for a Porsche to have a 15 gallon oil reserve. The oil cools better outside the engine also.
Rob
/ Who's better at estimating slope angles? #33
I disagree. I mounted a tiltmeter on my loader frame and all it takes is a quick glance when you think you're getting steep. It's a tool, would you give up the speedometer or tach in your car? Do they distract you from the road? Not really.
Also it doesn't work that way, what happens is that you start checking it when you feel you're getting to a bad angle, often times I've been at 15 degrees when I started checking, so it's gradual. This happens if I haven't been on a steep angle for some time. It's almost like I have to recondition my senses.
When I got my latest tractor I took it on hills to see how I felt at different angles and what the tiltmeter showed. being very careful I got the tractor pretty steep with no problems. Last winter when plowing I slipped off the driveway into a a drainage ditch. I though the tractor would roll over as it was about 25 degrees but it didn't and eventually I dug myself out. While I don't advise testing your tractor this way it does give an idea of how steep these guys can get.
Rob
/ Who's better at estimating slope angles? #34
My tiltmeter is mounted on the front right FEL "column" so it is easy to see it and what is around the tractor. Just like scanning the gauges but it takes less time. And if one is looking to the right front of the tractor the Tiltmeter is right in your line of sight.
This one section of ground that is worrisome is mowed in A Range and 1st gear so the going is slow. :D VERY slow. :D
When my FannyOMeter and the Tiltmeter say it is time to get out of the ditch we gets out of the ditch. I don't think I stay in the ditch past 15 degrees. Watching the Tiltmeter over the years tells you how small a hole, rock, stick, etc, can move the tractor 5 degrees.
Later,
Dan
/ Who's better at estimating slope angles? #35
Rob
Just like every operator is different, so is every tractor. Some are not safe at 15, some are still safe at 25.
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2015 Bobcat E42 (A64126)
2015 Bobcat E42...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
John Deere QA Adapter (A64126)
John Deere QA...
GENIE TELESCOPIC FORKLIFT (A65053)
GENIE TELESCOPIC...
