Who Uses CB Radios?
   / Who Uses CB Radios? #121
I was going thru some stuff of my Mom's; I came across her practice test for CB, from the early 1960's.
My Grandfather was an early adopter of CB. He was a HAM going back to the 1930's, and got one of the first CB's. Tube stuff... Him and my Mom said when the first CB's came out, most people just used their real name. Everyone was pleasant, no foul language etc. Everybody was licensed.
My cousin still has my Grandfather and his dad's(my uncles) Pace 23 channel rigs. They were big. The radios could be used mobile, or stationary.
Grandfather and Uncle talked about conversations with people in the Midwest and east if conditions were right; they were in N. Calif...
   / Who Uses CB Radios? #122
Ham radio is still like that today for the most part. Not sure if it's the licensing or the fact that it's less common.
   / Who Uses CB Radios? #123
I used to have CBs in both my trucks, one was a 'good' one, 'might' have been tuned up a bit... would really cover some ground, even when down in the hollers, matched to the antenna and the whole system checked with SWR meter. The other one was a basic Midland $40 radio and cheapo antenna, fine for close range, talking to other traffic on well roads and back roads.
Haven't had one in a truck for a few years, going to stick the little one in my daily driver soon, its laying in the back seat now, just need to hook it up.
   / Who Uses CB Radios? #124
Gravel pits use them around here. When I was working in their office, I thought, how primitive, thinking they used them for on site communications. Then I realized and observed how they could talk with any incoming or outgoing dump truck. VERY effective, and CHEAP!
They do the same here.
Also Asphalt plants use them to let the drivers know who is loading next and what silo to be under.
   / Who Uses CB Radios? #125
I still have the tube CB with desk microphone in the attic connected to a large rooftop antenna at Mom's... has not been on for years but did collect a lot of call sign cards at one time.
   / Who Uses CB Radios? #126
Yes, we use them at work daily (all the trucks have CB's and many of the company pickups), couple of miles is all that is needed.
As the FCC originally envisioned the Citizens Radio Service in 1958 that is precisely what they had in mind. The service was originally on 462 Mhz, but the state of the art in those days made it difficult to produce radios on those high (at the time) frequency's at a price point and with the reliability that people could afford. So some idiot at the FCC thought it might be a good idea to take back the 11 meter Amateur band as radios could be made much cheaper and much more stable at the much lower frequency of 27 Mhz and create what is known as the Class D Citizens radio service with the original 23 channels..
That was all well and good but no one thought about the sunspot cycle. For several years at a time 27 Mhz supports long distance communications at sunspot maxima. At sunspot minima only ground wave communications or the occasional Sporadic E propagation is possible. Ground wave with inefficient antennas is typically only a few miles, Which is exactly what they had in mind.
During periods of high solar flux (large amounts of sunspots) the band opens up for "skip", and communication is possible for thousands of miles, even worldwide if there wasn't such congestion on the channels (later expanded to 40 to try to help alleviate the congestion). The FCC originally tried to stop "hobbyist" type activity by making it against the rules to try to communicate long distances, but by then the genie was out of the bottle. They discovered that there was not way to police this particular radio "service" and in fact they even dropped the licensing requirements and the need for actual assigned call-signs.
As the sunspots die down, the people attempting to work "skip" lose interest as the band is "dead" with only local short ranges are possible. Also as pointed out other technology's have surpassed the need for highway information, and interest in CB radio has dropped even more, with so many of the radios either going in the dumpster, or thrown in a pile in the garage.
Someday when cycle 25 starts back up (theoretically a few years from now) who knows if the CB usage will increase or not. Time marches on, and this isn't 1979 any more. Smokey and the bandit is a distant memory. And if illegal hobby usage of CB starts up again, your legitimate and useful usage of CB for short range communications will suffer.
Ironically the old original 462 Mhz frequency allocation for CB that was called Class A at the time is now called the FRS or Family Radio Service. It is very popular, and unlicensed but only "walkie talkies" portables are used here. The GMRS or General Mobile Radio Service is next door and does allow mobile radios but as far as I know it still requires applying for a license. it is just a small amount of money and waiting on the license and callsign to arrive. The radios for the FRS are extremely cheap and are blister packed at wal-mart which is the lowest common denominator. They are so cheap, they are throw away items.
   / Who Uses CB Radios? #127
USUALLY, you will have a bit more respect for something you at least had to work a little bit for. Notice I said Usually. There are some rotten apples in the Amateur Radio barrell also. But they are for sure in the minority. If you are licensed, and forced to use a callsign which anyone can look up instantly to know who you are and where you are, it tends to make a person a bit more civil. By the way my callsign is KØUA. And I have been a licensed Amateur Radio operator for 48 years this year.
   / Who Uses CB Radios? #128
I agree with you, James( K0UA ). I was first licensed in 1968. Originally - WL7AHL Now - KC7SW
   / Who Uses CB Radios? #129
I have been a HAM since the 80s. But that is useless for this purpose. UHF CB, really? That is the band it SHOULD have been on all along.
There is "UHF CB" now. They call it FRS. It is available in those little walkie-talkie radios you can buy almost everywhere now. Unfortunately they put too many restrictions on it to make it useful. The prohibition of an external antenna means mobile use doesn't work very well.
   / Who Uses CB Radios? #130
Yep, I switched to a vanity call sign and got the letters/numbers mixed up while using it for the first time while mobile, someone on the repeater looked me up by my previous call sign and straightened me out fairly quickly.
Aaron Z
WB Mower (A50120)
WB Mower (A50120)
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2008 Ford F-350 Service Truck (A55788)
2008 Ford F-350...
MAHINDRA 6110 TRACTOR (A54756)
MAHINDRA 6110...
2020 John Deere HPX615E Gator 4x4 Utility Cart (A55787)
2020 John Deere...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
