Who still drives a stick in 2025?
   / Who still drives a stick in 2025? #121
As usual I fat fingered the comment. I meant 120 gallon tanks, but then I also suspect you knew that. Being 74, I sometimes need some slack.
In reality, twin 120's are median sized tanks. Some of the trucks in the fleet had twin 150's.
We were just having some fun, if we didn't bust your chops occasionally who would?
   / Who still drives a stick in 2025? #122
Have no clue about the capacity of a HHO truck. No one around here uses HHO. It's all either Nat Gas or propane if the Nat Gas isn't available. Used to be a few homesteads with electric heat but that went away long ago. Resistance heating is way too costly to heat with.
   / Who still drives a stick in 2025? #123
I started 50 years ago at 11 on a '42 Ford GPW(wwii war production Ford version of the Willy's MB jeep).
My favorite stick was Eaton 10spd behind a Detroit 8V92T in a GMC Topkick Water Tender for the fire dept. Otherwise have done 3spd on the floor, 3 on the tree, 4spd, granny 4spd, 5 and 6 speeds.
For traffic and commuting, an auto is great. For loader work, HST is great. For the rest a manual is great.
Just worked out that have autos at the moment.
   / Who still drives a stick in 2025? #125
My first car was a hand me down Subaru DL with all of 83 cubic inches. A 4 speed manual with cable that connected the clutch pedal to the throw out yoke. Cables lasted about 60K miles and would break. Drove home more than once using no clutch. As I was arriving at light, where traffic stopped, I would take it out of gear and coast to light. Turn of engine and engage first or second gear. Restart car while in gear, making sure I had plenty of room between me and car in front, and then proceed to rev match until next stop. Became good enough that I, for fun, would practice rev matching even when clutch cable was functioning.
   / Who still drives a stick in 2025? #126
MY kioti is stick. Actually Sticks... 1-4, + L, M, H + F/R ... :)
   / Who still drives a stick in 2025? #127
My second car was a Dodge Polara, 383 cubic inches with dual quad cross ram induction, with 3 speed push button automatic located to left of steering wheel on the dashboard.
Most recently a 3 speed no syncromesh manual and cone clutch made from leather on a 4000 pound car. Max engine rpm is approx 1500 so up and down shifts are relatively each to match. Massive straight cut brass gears in transmission
Ultrarunner, does that ring any bells?
Sounds like an EMF I worked on with leather clutch...
   / Who still drives a stick in 2025? #129
Not an E-M-F but one that existed on both sides of the pond and bodied by Brewster.
I'm curious as to your other experiences with pre war marques.
   / Who still drives a stick in 2025? #130
My ranch truck...it goes anywhere, never gets stuck and it never breaks.
UNUSED FUTURE STP45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
1804 (A58375)
1804 (A58375)
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
1998 PETERBILT 379 (A58214)
1998 PETERBILT 379...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
