Backhoe Who sells aftermarket backhoe thumbs??
   / Who sells aftermarket backhoe thumbs?? #1
gordon21
Lake Lure NC
JD 790
Can someone recommend a supplier who sells thumbs that could be retrofitted to a JD #7 backhoe that is used on a 790 and about half a dozen older JD models in the same size range. I would want a non-hydraulic model with 1-3 fixed positions. I remember seeing a post where the thumb had a shaft with a couple holes to adjust the angle/position. Something with pins where the thumb could be removed and leave only a couple small mounting brackets would be ideal. I can't weld, so whatever I buy needs to be a complete kit that I will take to a welder to attach.
I just ordered the hoe and it should arrive in a couple weeks and be ready. It would be great if I could get this work done at the dealer before I pick it up.
   / Who sells aftermarket backhoe thumbs?? #2
Recently I saw, either in this thread or in the Kubota owning and operating, a thumb on the bh of a BX23 or BX24. The thumb had continual adjustment by using a threaded cylinder and heavy threaded rod, much like an adjustable top link. If I can find it, I'll return here and post a link.
   / Who sells aftermarket backhoe thumbs?? #3
When I got my JD 110 TLB last December, JD had a non-hydraulic thumb just like you are describing.
I saved my pennies and just ordered an Addington hydraulic thumb, after reading about problems with the JD hydraulic ones. http://www.addingtonequipment.com/thumbkits.html
I do not know if the JD mechanical thumbs have the same problems the hydraulic ones have.
   / Who sells aftermarket backhoe thumbs?? #4
Why not visit your we have everything store, eBay? Here's one I found on a quick search backhoe thumb
Thanks PineRidge. That is exactly what I was looking for and the price is right too. Under $300 delivered and I am guessing about $50 to get it welded. Add another $15 for 2 cans of JD green paint and I am set to go for $325
   / Who sells aftermarket backhoe thumbs?? #6
Glad to help, don't forget to post pictures of your progress.
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
ROME GK-14 LOT IDENTIFIER 118 (A53084)
ROME GK-14 LOT...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
